Old 03-25-2014, 03:42 PM   #1
big_rig
Question Will this power steering pump work?
Hey guys, I tried searching but there are SO MANY power steering posts I can't find what I'm after.
I just finished installing my rebuilt engine (292, offy 4 bbl. intake, hedman headers) and I have a problem with my power steering pump. The previous owner mounted the pump in the picture with a home made bracket from the head and the other side with a square tube welded to the frame. I cut off the bracket from the frame and would like to install it properly supported from the engine. Can someone point me to a bracket that will fit this style pump or do I need to get a different pump and start fresh?
big_rig is offline   Reply With Quote
Old 03-25-2014, 07:39 PM   #2
65 C20
Re: Will this power steering pump work?
Check out the classified section.
There was a couple for sale there earlier.
65 C20 is offline   Reply With Quote
Old 03-25-2014, 11:35 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
This company on Ebay has bracket kits for PS on Chevy Inline 6 engines. They have two different ones for a 292 depending on what year water pump you are using.
http://www.ebay.com/itm/10004-PS-P-S...item337fb6c14e
http://www.ebay.com/itm/10003-292-CH...item33853839e2
These also work with aftermarket headers and intakes. Many of the stock ones won't work without stock intake/exhaust manifolds. Hope this helps.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-28-2014, 01:41 PM   #4
big_rig
Thanks guys, I read up on those Davis Speed brackets off ebay, seems to be the way to go and I will post pictures when they show up.
