fender emblem mounting
what do you call the things that go in the hole on the fender that hold the emblems in place and where do you get them? dont see them in lmc or classic parts and the guy at the parts store tryed to sell me a tube of glue.
Re: fender emblem mounting
The emblems just have speed nuts on the back.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
yea if you take the fender off to put the emblem on. i want the things you push in the hole then push the emblem into.
Barrel Nuts.
I'm curious how easy they are to get the emblems off afterward. Also, some concerns that the barrel nuts will chip the paint and start rusting. My emblems were held on with a tube of adhesive.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Yes ... barrel nuts. Some places call them barrel clips.
It depends on the condition of the emblem studs. If the studs are relatively smooth (never had a speed nut threaded onto them) then the emblem can often be carefully pried back off by working each end out a little at a time. The barrel nuts usually stay in the holes. But if the studs have threads cut into them, the barrel nuts tend to grip tighter and aren't as easy to remove. Yes, that can be a concern. There were some applications (like the trunk lid emblem on my Nova for example) where barrel nuts were used from the factory since there are no access holes for nuts on the inside. When I re-installed that emblem after having the car painted, I used a little bit of 3M strip caulk to keep water from getting in around the emblem holes and causing rust. Seems to have worked ... that was nearly 20 years ago and there are no signs of rust. |
thanks guys
Getting Old; Going Broke
It actually depends on the year as to how the fender emblem is held on. Some years used barrel nuts pushed in to the holes that retained the emblem studs. Some years used speed nuts on the back of the emblems on the studs on the back side of the fender.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
#8 | |
If you saw some vehicles with barrel clips on them you were probably seeing a vehicle that had been repaired in the assembly plant. Normally this would be because a wrong emblem had been installed (ie, Custom Deluxe emblem on a Scottsdale, Chevy emblem on a GMC, or whatever). By the way, the technique we used for removing them was to break them off. A small piece of wood placed on the emblem and a sharp whack with a hammer pops the studs off (or breaks the emblem in half). Insert a barrel clip, pop a new emblem on and ship it, all in 45 seconds or less. That would not be a factory installation. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
No, no. All the chrome was removed, the two-tone was single-toned, and it was painted with something that readily dissolves with lacquer thinner.
Heck, a lot of things have changed in ~me~ since 1977 (grin).
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate Last edited by SkinnyG; 03-26-2014 at 10:44 AM. |
