How About Using Old Tractor Steering Wheels?
Has anyone ever switched their stock steering wheel for an older style?
I done some research and I think a steering wheel off of an old Ford 8N tractor should work (same bore and splines) and be flatter and bigger in diameter at the same time. ![]() (sorry about the giant image)
Supercharged Scottsman Scottish by birth, American by law, Texan by the grace of God. “To avoid criticism say nothing, do nothing, be nothing.” ― Aristotle |
Re: How About Using Old Tractor Steering Wheels?
What year are you looking at putting it on? Maybe a 1938 but not a 1968
65 C20 292 4spd 4:56 Eaton HO52 |
meowMEOWmeowMEOW
Unless you took the tank out, moved the seat back, and weigh under 200lbs, a bigger wheel might not be a good idea. Tractor wheels can be up to 18+" across, WAY too big in a truck.
Also, aren't alot of those old tractor wheels SOLID cast metal? A 12 lb steering wheel might be useful to deaden the feel on a tractor, but I can imagine it would be nothing but a pain on the road.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I'm 6'0 and 160 pounds and with a stock bench seat my original steering wheel just barely fits me nicely, any larger diameter and even I wouldn't fit. Something to keep in mind.
Rockin' a '66 and loving every minute of it ![]() |
#5 | |
And I am looking for the lack of a large setback and something unique The stock rimblow has a 3-4" setback. Many older car and tractor wheels are flat
