Old 03-25-2014, 05:54 PM   #1
sambudo
sambudo's Avatar
question steering column noise
Recently doing ps steering conversion. I took off manual gear box, and now my steering wheel makes a grinding noise. Is there tension on the wheel when its all hooked up to the gear box? This is kind of strange that all of a sudden, my steering wheel is making noises, almost sounds as if the bearing in the column is bad. Has anyone else ever experience this be fore? Thanks.
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 03-25-2014, 07:45 PM   #2
JimKshortstep4x4
Re: question steering column noise
I don't understand why changing the box would affect the column or the steering wheel. It may just be a coincidence. The horn brush can make a lot of noise so I would suggest pulling the brush and put a small amount of grease on the end that contacts the turn signal cancelling cam.
There are two springs that put tension on the upper and lower bearings in the steering column so if you did nothing to affect the springs then the bearings should not be affected.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-25-2014, 10:54 PM   #3
sambudo
sambudo's Avatar
Jim
Thanks Jim strangest thing, yeah I agree with you, it must be coincidence. I'll disassemble the steering wheel tomorrow.
Is it hard to replace the bearing if needed? First I'll do as you said and see if this helps out.
Old 03-28-2014, 06:06 PM   #4
sambudo
sambudo's Avatar
Jim
I am pretty sure that I've had this problem for a while and didn't know it. after taking it apart I found the loose ball bearings.
