Old 03-25-2014, 11:17 PM   #1
coggonobrien
need lift recommendations 1969 blazer
I'd like to lift my blazer 4 inches, has stock springs. just curious what springs would be the simplest. are people using b52 kits on blazers? if the recommendation is to use later chevy stock springs where are people buying new one's and at what weight rating?
Thanks!
David
coggonobrien is offline   Reply With Quote
Old 03-26-2014, 07:21 AM   #2
72gmguy
72gmguy's Avatar
Re: need lift recommendations 1969 blazer
Why not just get a lift kit? I have a tuff country 2 1/2 inch all spring lift and 33's and I really like it!
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 03-26-2014, 11:19 AM   #3
coggonobrien
I guess I thought I put that in my post. Yes if there are good lift kits available that is what I'm interested in. Where is the best place to buy rough country from
Old 03-26-2014, 02:43 PM   #4
1972 Jimmy
1972 Jimmy's Avatar
I put a 4" BDS (Spring only) lift on my 1972 jimmy. I have no rubbing issues running 33" x 13.5" Nitto mudd grapplers. Springs are alittle stiff but that is to be expected.
Eric
1972 Jimmy is offline   Reply With Quote
Old 03-26-2014, 04:55 PM   #5
coggonobrien
did the bds come with shocks, brake lines, etc
Old 03-26-2014, 06:08 PM   #6
1972 Jimmy
1972 Jimmy's Avatar
Yes it was a complete kit. You can choose if you want blocks in the back or springs (I chose new rear springs due to the fact I did not want alot of axle rap during acceleration) So I went with 4 springs & shocks, steering arm, steering stabilizer shock, front & rear brake brackets, U-bolts. I attached these web address below.
http://bds-suspension.com/kit-customizer?kid=104H
Hope this helps you out,
Eric
Old 03-26-2014, 06:23 PM   #7
coggonobrien
thanks guy
Old 03-27-2014, 03:40 AM   #8
jamesjones
Freakin Awesome!
jamesjones's Avatar
If you want the best, call Deaver and tell them you want their long travel leaf setup. It can't be beat for the money IMHO.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 03-27-2014, 10:06 AM   #9
coggonobrien
I don't need the best. Just looking for a nice setup for a driver that is going there last.
Old 03-28-2014, 02:28 AM   #10
travis hillard
Just bought my 4 inch lift directly from rough country under 900 for all springs front and rear, 4 shocks, dual steering stabilizer, steering arm and extended brake lines. Tring to build a daily driver on a budget not a hard core 4x4. Hope this helps!
travis hillard is offline   Reply With Quote
Old 03-29-2014, 07:08 PM   #11
jamesjones
Freakin Awesome!
jamesjones's Avatar
I hear you. The Deaver setup will basically be about double of what you pay for one of the off the shelf lifts but it will ride like a Cadillac on and off road.
