03-25-2014, 11:29 PM | #1 |
Thoughts on a b&m th400 & cpp trans crossmember
Have a opportunity to pick one up, I have read good and bad. Price seems right but input from actual users would be great! It would go behind the gm crate 350 I just bought that jegs had on sale and replace a 4 speed granny. It comes with a cpp transmission crossmember also brand new.
03-25-2014, 11:32 PM | #2 | ||
"I ain't nobody, dork."
Re: Thoughts on a b&m th400 & cpp trans crossmember
The TH400 was originally designed to handle the TQ of BBC's, so they will rob a little power from a stock SBC. But, that being said... they are the best 3 speed slush box The General ever made.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
03-25-2014, 11:34 PM | #3 |
Can I offset that with the correct torque converter? And what would be the correct stall speed?
03-25-2014, 11:52 PM | #4 | ||
Is everything stock? Just use the stock converter.
Gary
03-26-2014, 12:03 AM | #5 |
For the most part it will be close to stock I will use a edelbrock 1406 carb, edelbrock 2701 eps performer intake, mallory 8548201C & hyfire and true ram 2 1/2" ram horns.
I plan to upgrade heads and cam down the road. I do not have a torque converter at this point, I will have to source one if I buy the th400. |
03-26-2014, 08:33 AM | #6 |
TH400 is a great transmission so if you want to get rid of the manual it's a great choice. Depending on your plans for the truck though you might be better served looking for something with an overdrive.
Anthony '67 Shortstep (555/T56) '67 Parts Truck (TBA) |
03-26-2014, 06:04 PM | #7 |
I know the the TH400 is a bullet proof transmission, I am looking for those of you with experience with the ones produced by B&M. I know some of you have to had some experience with them. Would you pick a new one up if the price was comparable to a rebuild?
03-26-2014, 06:43 PM | #8 |
I have the B&M T400 behind a 450 HP 383 with a Gear Vendors OD and I have had no problems with it. I had it rebuilt and a shop in LA built the TC to match the gears and HP I have.
69 Chevy 4x4 383 Power |
