Old 03-26-2014, 01:04 AM   #1
BADAZ chevy guy
BADAZ chevy guy's Avatar
73 - 87 rear spring mounts
So, I have an idea I want to run past the group here. What if I redesigned a set of front and rear spring hangers (for the rear leaf springs) that mounted tight to the side of the frame rails instead of offset like the factory hangers? I'm thinkin' I'd gain an extra 2 or 3 inches in width for wider tires
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 03-26-2014, 01:33 AM   #2
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: 73 - 87 rear spring mounts
People do that already. They even inboardthem. TThe problem is only if you are towing and such, you will lose some stability from the rear and will want to run a sway bar in the rear to make up for it.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-26-2014, 08:36 AM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
Or just on the bottom of the rail. Like an import truck.
Gain 3" more.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 03-26-2014, 10:52 AM   #4
83GMCK2500
1-ton perches sit closer to the frame than 1/2 & 3/4-ton. I think about 1.5" on either side.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
