![]() Join Date: Jun 2006
Would you guys happen to know if the GMC's that had/have the 305e V6 had stiffer front springs than the V8 trucks? I got my 65 minus that tank of a motor and I have no give what so ever in my front end.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Front Springs
I don't know for sure, but I would imagine that those springs are pretty stiff. Those GMC V6's are a good bit heavier than a Chevy big block.
![]() Join Date: Feb 2011
Re: Front Springs
Yeah, the V-6 engines weigh about 800lbs so it's a good bet they are stiffer.
MusicMan70 1961 GMC Suburban |
Re: Front Springs
Stengle Bros carries them with the correct load, might be made to order though. My Brother in law just had them make a set for his 63 V6.
http://www.stengelbros.com/ |
Re: Front Springs
That's good to know, I will be buying drop springs to replace them then since the 4.8L LS engine is so much lighter.
