Anyone running skinnies on steelies?
I'm going to have to buy tires soon (mine are so old and hard that they have nearly no traction). Thinking about trying some taller and narrower tires on my 15x6.5 ralleys. Anyone have experience with this? Got any pics of a similar setup? I currently have 255/60's on it, but I'm thinking of going to something like 235/75, or maybe even smaller in front.
Let me know what you think! |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Anyone running skinnies on steelies?
On my daily driver, I'm running stock 15x6 wheels all the way around. The rear tires are 235/75-15 and the fronts are 215/75-15. It's lowered 5 in the front and about 6 in the back.
![]() I like this combo because the tires are stupid cheap, the rear tires keep the speedometer accurate, and the front tires clear when lowered.
That's exactly the combo I was thinking about! I was even looking at bfg all terrains inn those sizes. They don't fit the "stupid cheap" category, but I know that they have good traction for winter, ride smooth, and last a long time. Just not sure if they are a bit too "off road" looking for a lowered 2wd...
My rear tires were free to me. They're some Goodyear Wrangler semi-off road tread. The fronts (Kuhmo brand) were 130 dollars per pair, out the door, from my local Discount Tire.
I built that entire truck for less than some guys are spending on a set of big low profile tires. I wish I had some bad assery on there but it just wasn't in the budget.
Here is a poor picture of my Goodyear rear tires. I flipped them around to put the letters inward when I powdercoated the wheels.
![]() Obviously that picture was taken part way through the project. The tires were what was on the truck when it was given to me. ![]() ![]() The 215s on the front. ![]()
I've got P235/75R15's all the way around, but on 15x8 wheels.
I'm a cheap guy, too. I turned the whitewalls in and painted them black with Krylon. I'm also faced with a unique problem, in that the spare in the pickup box is visible when viewed from the backside - so - I painted that whitewall black with Krylon, too. It's been 5 years and it still looks fine. K ![]() ![]()
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
I completely get the whole budget aspect. I'm trying to keep mine on the cheap as well. I think I have about $2500 in it as it sits right now. Once I get my carb issues sorted, and get it licensed and registered, all that will be left are paint and interior. I think that the interior is going to be the single most expensive part of the project. The parts are expensive - and I have not had any luck on CL finding anything. I'm going to try and get as many miles as I can out of my existing tires, but they are so hard that my little six can't hardly get moving without a burnout!
#8 | |
How low is your truck Keith? Mine is dropped about 5/6
Keith, I've always wondered what size wheels you were running. I don't remember seeing it in your build thread. Not that it isn't there, but I don't remember it. I have 15X8 wheels, too. I'd like to put my spare in my bed like yours, but I can't seem to find a spare carrier for the bed that will fit an 8" wide wheel. Did you make your carrier yourself?
One other question. I'm finally lowering my truck this weekend 4.5 in the front and 6 in the rear. Then it's off to an alignment and new tires. Does anyone know if I'll be ok with 235/75/15 tires front and rear with no rubbing on that drop?
Azulita - 84 Chevy Scottsdale Longbed 305/350 |
#11 | |
Which snubbers need removed? I have dropped spindles and springs and about 5" drop, so I assume I need to remove mine as well?
#13 |
ChevDog1, I think he's referring to the bump stops on the control arms. They're located on the underside of the upper control arms. They have a rectangular base with a pyramid type shape on the top of them.
I was planning on removing those when I rebuild my control arms this weekend. However, I don't think new front bump stops came with my drop kit. Any suggestions on lower profile ones to put up there, or should I just run without them? I'm bummed to hear that there is rubbing with 235/75/15's up front. I wanted to stay with the same size tire all the way around for tire rotation/spare replacement issues and for aesthetics as well. I wonder if 225/75/15's will be too small.
#14 |
Looks like another item on my todo list. I still need to cut off the rear bumpstop mounts.
#15 | |
K
#16 | |
I have made them in the past, though. Just used a hat section (probably a section cut from the factory underbed carrier) with a slot in it, mounted to the inside of the bed. I made my own "T" bolt but a standard carriage bolt would probably work. I'm probably 3" all the way around. Fairly conservative on this truck. I did a 4/6 on the blue truck, with the factory LR60-15 tires on the 15x7 aluminum wheel. I don't recall any rubbing (but I did have to go slow over railroad tracks). K ![]() ![]()
#17 |
Thanks, Keith. Right now I have 235/75/15 tires on the front and 225/75/15 on the rear. That's how the truck was when I bought it in September, and I haven't changed the tires because I knew I was going to be getting new ones soon. I'll lower the truck and drive with the 235s and 225s on the front and see how bad the rubbing is.
As for the spare tire carrier, I can't seem to find one using that RPO code. Do you happen to know a part number for it? When I look up the RPO code, it just goes to websites explaining the RPO codes.
