Old 03-26-2014, 04:27 PM   #1
lha1992
lha1992's Avatar
The joys of wiring....1965 c10 harness blues
Hi all, well been working on my 65 c10. Yanked the original 283 an powerglide outta it with the help of member dillon rock on here. The truck is a original 283 powerglide custom cab BBW with all the gauge instruments in the cluster.
So I was doing some wiring an was planing on rebuilding my engine harness with new wires going to the starter an coil an because I'm getting rid of points. Well heres the thing the truck never would start on its own from the key so you'd have to jump it from the positive side on the battery to the s-terminal on the starter with speaker wire. I figure maybe the harness or the neutral safety switch which I have another mystery about that coming up too.
Anyways theirs 4 wires coming outta the big plug on the end. Purple is to the s-terminal, green to my thermostat gauge sender, that weird colored cloth wrapped one is the resistor wire I imagine which goes to the r-terminal on the starter which then in the background you see the yellow wire that comes to the coil from the starter BUT what is the black one???????
I'm dumbfounded as to what it is an kept looking at the wiring diagrams for awhile. Either I'm clueless an not realizing it but WHAT IS THE BLACK WIRE?
lha1992 is offline   Reply With Quote
Old 03-26-2014, 04:33 PM   #2
lha1992
lha1992's Avatar
Re: The joys of wiring....1965 c10 harness blues
Another mystery I have right now is the truck has a weird wire coming off the neutral safety switch going to the wires where the horn relay is on the core support. I'll take pictures for that.
Old 03-26-2014, 04:36 PM   #3
Lugnutz65
Lugnutz65's Avatar
This is from the FSM with my added color. Maybe it is the dark blue and not black. I hope it helps.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 03-26-2014, 04:41 PM   #4
lha1992
lha1992's Avatar
Thank you for the help! That's the thing though my truck is an original all gauges cluster truck not warning lights. So why would their be a oil sender wire there at all? The date codes on the truck all point to the time of when the truck was built an everything.
Old 03-26-2014, 04:47 PM   #5
Lugnutz65
Lugnutz65's Avatar
Let me dig out my FSM and have a look.
Old 03-26-2014, 04:49 PM   #6
lha1992
lha1992's Avatar
Thanks brother! I'm quite lost as to what it could be at all. Been looking an trying to figure it out an nothing.
Old 03-26-2014, 05:40 PM   #7
ray_mcavoy
That black wire is part of the factory ammeter ("BATT" gauge) wiring. It should go to the large BAT stud on the starter solenoid.
If you look up the wiring diagrams in the FSM, they don't show the optional factory gauge wiring for the 10-30 series trucks. You have to refer to the diagrams for the larger medium/heavy duty trucks instead.
GM put 4 amp inline fuses in the ammeter wiring on the later year 67-72 trucks. I highly recommend adding them to the 64-66 ammeter wiring. They'll save the ammeter and it's wiring from burning up if a poor connection develops on one end of the shunt wire and forces too much current to go through the ammeter itself.
ray_mcavoy is offline   Reply With Quote
Old 03-26-2014, 05:50 PM   #8
Lugnutz65
Lugnutz65's Avatar
These pics are from the wiring section of the 1965 FSM supplement. I compared these diagrams to the 1963 FSM and they look the same. All of the V8 wiring diagrams have a black wire (B) going to the middle post on the starter solenoid. Yes, the same post that has the POS+ battery cable. That means the black wire is HOT at all times. The other page shows the black wire (B) terminates on the AMMETER.
I'm trying to help but need to give a disclaimer. I am not an electrical guy so please check this info out with someone else before you fry your instrument panel because I gave bad info.
Here are the pics. from the FSM. The bottom of the page doesn't say C10 but ALL the V8 diagrams show the same wiring for the BLACK (B) wire.
Old 03-26-2014, 05:54 PM   #9
Lugnutz65
Lugnutz65's Avatar
Rats, Ray beat me to the answer! But ooooooonly because I was taking, editing and uploading pictures!
Old 03-26-2014, 06:21 PM   #10
lha1992
lha1992's Avatar
Thanks guys for all the help! I really had no clue that that was for the ammeter. I looked at the wiring diagrams for the 10-30 trucks an nothing but as you said it wasnt to be found in the light duty trucks manual.
So with this do I need a big end hook to loop onto the BAT terminal on the starter?
An per suggestions from ray I will do the inline 4amp fuses on the black wire.
Old 03-26-2014, 06:24 PM   #11
lha1992
lha1992's Avatar
You guys are the best thanks!!!!! :-)
Old 03-26-2014, 06:26 PM   #12
Lugnutz65
Lugnutz65's Avatar
That's what I would do. Ring connector on the starter end of the wire and an inline fuse.
Old 03-26-2014, 06:45 PM   #13
ray_mcavoy
I agree.
In addition to placing a 4A inline fuse in this black wire, I'd also recommend adding a second 4A inline fuse to the other leg of the ammeter wiring. One fuse is enough to protect against an overload due to a bad shunt connection (as I mentioned earlier) but a fuse in both wires will give full protection in case either side gets shorted to ground.
The other leg of the ammeter wiring is the black wire with a white stripe. It connects to the junction block on the horn relay (with a bunch of red wires) as shown in the diagram Lugnutz65 posted above. Locate the fuse close to the horn relay end of that wire.
Old 03-26-2014, 07:13 PM   #14
lha1992
lha1992's Avatar
Originally Posted by ray_mcavoy View Post
I agree.
So you are saying place one on the wire that's listed B/W that goes to the horn relay from the ammeter?
My truck has had pretty bad hack jobs of PO's working on the wiring such as they put a volt meter in wired from some boxthing on the fire wall thatsn tied into the BAT terminal on the alternator that also feeds one of the spot lights. I'll get more pictures up in just a bit of it all.
Old 03-26-2014, 07:32 PM   #15
TJ's Chevy
TJ's Chevy's Avatar
Ah the joys of wiring! Least some people here know how to do this stuff! LOL! When it comes to wiring for me..
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-26-2014, 07:41 PM   #16
ray_mcavoy
Yes, that's the wire. I forgot to mention that the diagrams use the abbreviation "B/W" for black with white stripe but it looks like you figured that out
The fact that they added a volt meter is probably a good indication that the factory ammeter quit working. It could be as simple as that black wire no longer being connected to the starter solenoid BAT stud. But while you're working on the wiring, it would be a good idea to take a close look at the rest of the ammeter wiring (including the wires under the dash) just to make sure it's all in good condition and still connected as shown on the diagrams Lugnutz65 posted.
Old 03-26-2014, 09:44 PM   #17
Dillon Rock
Heck man I should've given ya the wiring harness diagrams from my stash. I also have a new wiring harness sitting under the bench in the garage for the cab. All complete as far as I know. All I did was snag a fuse block clip for my radio spot and that's all I did to it. I'll let ya have it for nothing. No need for it on my part.
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie.
Dillon Rock is offline   Reply With Quote
Old 03-27-2014, 02:43 PM   #18
1963c-10
1963c-10's Avatar
The oil gauges were plumbed in, no wires....the warning lights had wires for the oil warning light.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-27-2014, 03:04 PM   #19
kieth
kieth's Avatar
Wiring you either love it or hate it, I enjoy it, One thing we found as we added the wiring harness from a 91 suburban to my 66 gmc as we rebuilt it, was that GM had not changed the color codes from 66 to 91, all the old color codes still went to the same thing and new devices had new wires with new color codes. Sure made wiring the gauge cluster a lot easier to adapt to the newer wiring harness......Kieth
kieth is offline   Reply With Quote
Old 03-27-2014, 03:14 PM   #20
1963c-10
1963c-10's Avatar
Now that's good info Keith....never knew that. Thanks..
Old 03-30-2014, 08:30 AM   #21
lha1992
lha1992's Avatar
Hahaha wiring its fun but can be a challenge an can make you pull your hair out haha. All I say study those wiring diagrams. I work on vintage stereo equipment anyways with restoring those old things so doing this I kinda am use to it but still your working on a bigger scale an you don't wanna mess up something then go boom lol.
Thanks for all the help ray! I am going to go ahead an check the rest of the ammeter wiring to be safe before hooking the gauge backup an sending power through all the wiring. You have a point maybe that's why they added it but idk the truck was setup to pullna trailer cross country apparently cause whoever owned it in the past traveled a lot which I'll post why they mighta added that meter in a bit.
Thanks man!!! Its cool about the wiring diagrams I can use them when you get back. But that harness will for sure come in handy I can tell ya that!!! I owe you big time man thanks!!!
Exactly that's what my truck is is the oil gauge was plumbed in an how could it have a oil warning light which then with the help of the guys who posted above helped me find out the black wire was for the ammeter.
Thanks for the info kieth!!! I'll deff check out the 73-87 trucks if I need anything extra.
Old 03-30-2014, 08:34 AM   #22
lha1992
lha1992's Avatar
Well guys here's my next question an its a odd one I don't understand what the heck the previous owners were thinking? Unless I'm overlooking something yet again but anyways in the picture below you'll see the mess underneath my dash but look closely at the neutral safety switch an you'll see a brown wire hooked up.
An here's the mess.
Now that brown wire goes all the way through the firewall to some hookup on the horn relay! As you'll see below the brown wire hooked to the horn relay. And I'm not talking about the brown wire hooked directly to the horn I'm talking about the brown wire hooked to the center connection on the relay itself.
Here's a better picture where you can see the brown wire i'm talking about. (Not the brown wire hooked to the horn but the one on the horn relay)
Sooooo you guys what do you think that wire is running at all???
Old 03-30-2014, 05:10 PM   #23
ray_mcavoy
The auto trans neutral safety switch also contains a set of contacts for reverse lights. They were an option on these trucks (and became standard equipment in '66). The 2 screw terminals on the horn relay are a BATT+ power distribution point.
It looks like someone added reverse lights to your truck and used the brown wire connected to the distribution point on the horn relay as their power source.
The factory installed reverse light wiring used a dark green power feed wire connected to the fuse box. Did they at least put an inline fuse in that brown wire?
An here's the mess.
Yikes! That does look like a mess!
... I also have a new wiring harness sitting under the bench in the garage for the cab. All complete as far as I know. All I did was snag a fuse block clip for my radio spot and that's all I did to it. I'll let ya have it for nothing.
Looks like you're all set with a good harness to replace that mess though
