Old 03-26-2014, 10:51 PM   #1
C10agent
C10agent's Avatar
Lower Ball Joint - Do I have the Wrong One??
Hey guys,
I just replaced the passenger side drop spring and I am was putting everything back together and noticed that the nut tightens farther than the pin. Do I have the wrong lower ball joint in?? The PO has a washer in between the spindle and nut on the upper ball joint, does that matter?
Neil...............
1972 C10 SWB - Shop Truck in the Works
5.3 LS / Full Air Ride / Rear Notch
20" American Racing Daytonas
IG - neilioustx - pictures of build/progress
Born and Raised in the Promised Land....
TEXAS Y'ALL!!
C10agent is offline   Reply With Quote
Old 03-26-2014, 11:33 PM   #2
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Re: Lower Ball Joint - Do I have the Wrong One??
Seen lots of them with a washer between spindle and nut .... shouldnt be any problem no further than it extends thru if it is tightening up alright .
ksbrktracer is offline   Reply With Quote
Old 03-27-2014, 02:04 AM   #3
Highlander72
Could be that the taper in your spindle is worn (maybe had a loose ball joint previously). Does the ball joint taper tighten up snugly in the spindle (as in in-out movement)?
'72 C10 Highlander | '69 GTO | '06 VFR800 | '96 XR250
Highlander72 is offline   Reply With Quote
Old 03-27-2014, 06:09 AM   #4
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Ktracer I like that avatar and I find it odd , because almost all of the classic car chevy guys will throw out a ford joke , and the ford guys will throw out a chevy joke , but nobody ever even mentions that dodge and plymouth vehicles exist LOL good job !
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 03-27-2014, 08:33 AM   #5
steelhorse
steelhorse's Avatar
A washer should be fine. A lot of newer cars use them for the same thing.
steelhorse is offline   Reply With Quote
Old 03-27-2014, 09:10 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
I would say that something is wrong. No way the stud should pull in that far. I think you have the wrong ball joint.
Posted by member "Bus Ted Knuckle"
For 1/2 ton:
67-70 are same uppers and lowers.
71-72 are the same, they are different than 67-70 (the older ones have smaller diameter studs in the ball joints).
71-72 spindles will work on 67-70 control arms, you must use the newer ball joints, and the complete newer tie rod. Any year ball joints will fit in any year a arms, upper and lower. You will also have to trim the steering stop on the disc brake spindles. you can also use 73-87 spindles, but you must also use the newer BJ, and TR.
For 3/4 ton, someone else will have to chime in
LockDoc
Leon
Old 03-27-2014, 01:26 PM   #7
kwmech
Quite common, just make sure that the washer is hardened such as a grade 8 flat. Although you may want to make sure that the ball joint was not misboxed. The taper between 70 and before and 71 to newer were a different degree of taper. That could cause the same thing
Old 03-27-2014, 11:05 PM   #8
tcoop68
tcoop68
tcoop68's Avatar
I could not trust it I would recheck .
tcoop68 is offline   Reply With Quote
Old 03-30-2014, 03:33 PM   #9
C10agent
C10agent's Avatar
Thanks for all the info guys. I am trying to find some washers to fit, looks to be 5/8", does that sound right? I went to lowes and couldn't find what I was looking for. I would replace but they are in great shape and replacing is a pain in the arse. Any ideas where to find them??
Neil...............
TEXAS Y'ALL!!
Old 03-30-2014, 09:06 PM   #10
ksbrktracer
TNT-MOTORSPORTS
Fastenal might be a good choice if you have any close by. I couldnt find any that fit snug enough on the stud so I made some myself by enlarging the hole to the size I needed. My Local Ace Hardware sells thick AN washers that are Grade 8. Sometimes looking at Metric will get you a washer that fits properly. I hate washers that are drilled 2-3 sizes oversize.
This is the closest I saw to you.
FASTENAL
41212 Park 290 Dr
Waller, TX 77484 (20.3MI from Navasota) (936) 372-1134
Old 03-30-2014, 09:10 PM   #11
C10agent
C10agent's Avatar
Nobody hang me but is a lock washer a bad idea?
Neil...............
TEXAS Y'ALL!!
Old 03-30-2014, 09:14 PM   #12
ksbrktracer
TNT-MOTORSPORTS
I personally wouldnt , will chew up the spindle to start with.
Old 03-30-2014, 10:00 PM   #13
elf w/capital T
Yeah, use a normal flat washer
elf w/capital T is offline   Reply With Quote
