Old 07-26-2003, 10:35 PM   #1
brad20653
XE268 cam
Where can i get this cam ? Is it good for low end power ?
brad20653 is offline   Reply With Quote
Old 07-26-2003, 10:58 PM   #2
73stepside
73stepside's Avatar
it's a good cam but is lacking in the lowend torque production. you should be able to get it from jegs or summit. you might be able to special order it from your local auto parts store
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 07-27-2003, 01:29 AM   #3
Jwill41
Jwill41's Avatar
i just ordered the xe262 from jeg's
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 07-27-2003, 08:40 AM   #4
brad20653
whats good for low end then ?
Old 07-27-2003, 11:29 AM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
If you want to use a Comp XE series cam, the XE250 or XE256 would be really good for low-end power. They would also give you pretty good throttle response and MPG, but they would stop making power over 4500 rpm or so.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-27-2003, 01:15 PM   #6
crazy longhorn
Fabricate till you "puke"
the XE268 is pretty tame in a 383......very mild lope, & power just up off idle. I shift mine @ 5800-6000 under full throttle. that same cam in a 350 will be a little more "rowdy", & will like about 2500 on the stall with an auto trans. If you have 3.73-4.10 gears,& a loose converter the cam will work good in a 350....i do agree that low end power will suffer a bit tho(as well as milage). Depening on gearing,& useage I would look at the XE256, or Xe262 for a 355. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-27-2003, 02:04 PM   #7
jhwkns
Registered Cruiser
jhwkns's Avatar
Our local Auto Zone has them on the shelf.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 07-30-2003, 02:50 AM   #8
73stepside
73stepside's Avatar
mine pulls good to 5500 that's where my tranny shift point is set. it is only rowdy when the motor is cold it'll lope real good, but when it's warmed up you can barely tell it has a cam in it.
04 GMC Sierra RCSS
70 CST LWB
