Old 03-27-2014, 11:43 AM   #1
wayno
Horn Relay
So I'm rewiring under the hood trying to get things cleaned up - adding fusible links - distribution blocks - relays for the lights and electric fan and started staring at this huge horn relay - given I am rewiring and adding distribution blocks at the core support and one at the firewall that I will use to shorten the power-up wire to the fuse box and give myself clean places to connect to power - can I replace this oversized relay with a small relay like I'm using for my lights and fan?
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 03-27-2014, 02:31 PM   #2
ray_mcavoy
Re: Horn Relay
Originally Posted by wayno View Post
... given I am rewiring and adding distribution blocks at the core support and one at the firewall that I will use to shorten the power-up wire to the fuse box and give myself clean places to connect to power - can I replace this oversized relay with a small relay like I'm using for my lights and fan?
Yes, you can replace the stock horn relay with a modern relay like the ones you're using for your headlights & fan. The two screw terminals on the stock horn relay served as a power distribution block. But that is no longer needed since you're adding your own distribution blocks.
ray_mcavoy is offline   Reply With Quote
Old 03-27-2014, 03:27 PM   #3
wayno
Re: Horn Relay
Thanks Ray - was hoping you were going to say that. Sherman Maine... near Sherman Mills? Grew up downeast - Calais / Eastport area. Thanks again.
-W
Old 03-27-2014, 04:21 PM   #4
ray_mcavoy
Re: Horn Relay
You're welcome! Yeah, Sherman and Sherman Mills are the same town
