how do you adjust doors that sit too high?
The drivers side sits perfect and closes so smooth but the passanger side has to be slamed really hard and is pretty tough to even open. The top of the door rubs on the top of the cab. Any suggestions??
I can upload a picture by tomorrow to give you a better idea. |
Re: how do you adjust doors that sit too high?
use a floor jack and loosen the hinges on the cab..let the jack down slow and adjust to fit.. also adjust the strike plate.. p.s put floor jack on the fat part of the bottom center of door..
efi 496bbc th350 custom brakes narrowed 9 coilover rear. |
Check to make sure door hinge pushing a are not wore out. Open door 1/2 way an grab outside handle an rock door up an down. If you feel movement in bushings , replace them otherwise you'll just be chasing an alignment issue
And take the cowl corner off to keep form denting your door.
![]() Join Date: Jan 2011
Take the strike plate out first and see where the door sits. Adjust as needed for alignment and then put the strike plate in. You may find the door drops and fits better with no strike plate in there.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
