Old 03-28-2014, 02:46 AM   #1
Cowboy5
Cowboy5's Avatar
Body Lift
Hello again, I am planning on lifting my 72 about 4". But I found a body lift alot cheaper than buying a brand new skyjacker or roughcountry. Which are good lift kits dont get me wrong just dont have that kind of money. Would I have to change or alter anything if I install just a 3" body lift.
Cowboy5 is offline   Reply With Quote
Old 03-28-2014, 04:32 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Body Lift
I would never run a 3" body lift. The larger the gap between the frame and the body, the more stress on the mounts. I have a 1" lift that gives that little extra tire clearane and helps clear exhaust, PS hoses and things like that.
here is a link to some general instructions...
http://static.summitracing.com/globa...um-7852300.pdf
What I used was a rear flip kit to gain 4" rear lift with stock rear springs....
http://diy4x.com/cart/index.php?rout...product_id=112
Rich
1972 K5 Blazer CST Click HERE
Old 03-28-2014, 09:43 AM   #3
mjjjracing
Re: Body Lift
I would never run a body lift at all , you can find a used lift kit or save your money and wait to put a correct lift on your truck. you will be happier in the end . Just my 02 cents Jim
39 GMC pickup,70 GMC K1500 short bed 4x4 ,72 K10 short bed step side 4x4 ,71 short bed fleet side , 72 K20 long bed ,74 K10 long bed , 69 C30 dump bed dually, 79 K30 standard cab dually , 02 Dodge 4x4 dually
mjjjracing is offline   Reply With Quote
