Old 03-28-2014, 09:57 AM   #1
blazer2007
looking for rear taillight wiring harness
I,m looking for wiring harness just from the rear lights up to the cab but don,t see any in my catolugue for a 78 Does any vendor sell them or should I just make my own?
blazer2007 is offline   Reply With Quote
Old 03-28-2014, 09:05 PM   #2
silverbear
silverbear's Avatar
Re: looking for rear taillight wiring harness
Senior member "hatzie" has a link to several manuals in his signature. Do a search for him and then look up your truck in the links.
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
Old 03-29-2014, 10:00 AM   #3
mikentosh
mikentosh's Avatar
Check with M&H Electric. They should have what you are looking for. It might take a bit of time to build you one but their quality is worth it.
mikentosh is offline   Reply With Quote
Old 03-29-2014, 01:13 PM   #4
hatzie
Moderator
hatzie's Avatar
This guy makes them.
http://www.mrtaillight.com/product_i...roducts_id=673
Just looking at the picture...
  1. Grounding wires??? I don't see the factory ring terminal grounds that go behind the tailights and I also don't see more than 4 wires at the unterminated tailight to main harness tails.
  2. The 1156/1157/194 bulb sockets are overmolded on the harness instead of the factory style sockets. The overmolds will probably hold up for several years but I'm not sure how well they'll work in another 20.
  3. The license plate light connectors look like unsealed 1/4 disconnects. This is not the place to have un-sealed connectors. Single or two position Weatherpaks are what I would use. You can probably request those or trailer style bullet overmolds.
  4. No molded connector to mate with the 1978 OEM harness. Not neccesarily a negative. You can probably request the 85-91 Delphi Weatherpak 2x2 connector 12015798 on his harness and install the Delphi Weatherpak 12015024 mating half on yours in place of the 73-84 overmolded GM connector... or just install your own Weatherpacks.
I've done this connector update several times. Mouser Electronics has a nice little feature called projects that allows you to save a Bill of Materials for a project and then share it with anyone. I put all the pieces to assemble male and female Delphi Weatherpak 2x2 connectors together so I could order them or share a BOM with descriptions and OEM part #s.
This link ---> will take you directly to my Mouser Electronics Delphi Weatherpak 2x2 4 position connectors, terminals, and seals "saved project".
GM Circuit #s
# 9 Running Lamps
# 18 LH Turn
# 19 RH Turn
# 24 Backup Lamps
Wiring diagram follows. More info in this thread -->http://67-72chevytrucks.com/vboard/s...d.php?t=612960
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-29-2014, 10:15 PM   #5
mustardrocket
I decided to order one of the rear tail light wiring harnesses. I had been having taillight issues for years. I'm not much for wiring, but I should be able to adapt weather tight plugins. I'll post on it when installed.
mustardrocket is offline   Reply With Quote
