Old 03-28-2014, 12:28 PM   #1
seanrolandwood
th350 questions
Ok so I have a chance to pick up a th350 for FREE I was just wondering if there was a simple way to identify a PG V. TH350 visually......... I know they are the same length same bolt pattern ect....what I'm wondering is the vacume line in the same spot some numbers I could use to help identify said transmission I've searched and anytime someone asks the obvious is put out there then it's just a bunch of people talking about how they would rather use a 700r4 or this or that and then talking about how they think this is different. Please I'm just looking for someone thats really familiar with the transmissions and can get me an answer that a layperson could understand and spot as I dont wish to bring home parts I can't and don't want to use free or not
seanrolandwood is offline   Reply With Quote
Old 03-28-2014, 12:35 PM   #2
PGSigns
PGSigns's Avatar
Re: th350 questions
Easy way if you are not good at the gm trans is the shape of the pan. There are pics on google for this. But the powerglides have powerglide on the side of them so that also helps.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-28-2014, 12:38 PM   #3
ACK
ACK's Avatar
Re: th350 questions
Here's visual guide for ID'ing transmissions ... http://www.roadkillcustoms.com/hot-r...#axzz2xHBJmrce
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 03-28-2014, 12:42 PM   #4
ACK
ACK's Avatar
Re: th350 questions
And here's how to tell a TH350 with and without a lockup ...
Old 03-28-2014, 01:15 PM   #5
seanrolandwood
Re: th350 questions
Thank you for the diagrams and the fact that powerglide is stamped on the case should make this easier thanks for your time and info and while I'm here any opinions on what gear ratio works best with a 350/350 setup for a balance between gas mileage and power 3.55.....3.73...I'm building my truck as a daily but I also dont want my truck not to be able to get out of its own way but I'm not exactly looking to catch scratch at 40 either anyone willing to put their numbers out there and what kind of mileage you're getting
Old 03-28-2014, 01:50 PM   #6
PGSigns
PGSigns's Avatar
Re: th350 questions
3.42 if you can find one.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-28-2014, 02:08 PM   #7
seanrolandwood
Re: th350 questions
Thanks jimmy and ack I'm heading out shortly to go check out the trans. and I just wanted to say thanks for the quick response and helpful information I'm new around here and lets just say I wasn't having much luck with another forum that will remain nameless but wow are the people that frequent that board something else I'm sure its not all of them cause I recognize a few builds here from there I just must have had bad luck so far all the talk about this board is turing out to be true
Old 03-28-2014, 04:38 PM   #8
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: th350 questions
3.73's are fun on the street, but may be too low on the highway.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-28-2014, 10:11 PM   #9
davbowen
davbowen's Avatar
Re: th350 questions
th350 is a 3 speed, pg a 2 speed. check the lever positions
davbowen is offline   Reply With Quote
