Old 03-28-2014, 04:59 PM   #1
JayPeee
'61 GMC w/ 65 Chevy Grill & Bumper
I have a question for you guys. My truck is actually a '61 GMC but what looks to be a 65 Chevy grill and bumper? Anyway...I noticed that the bumper is mounted a little weird. I looked on the LMC Truck site and it doesn't look like I'm missing parts or anything. It almost seems like I need to add some spacers / washers to push out the bottom. That or the bumper horns are bent?
JayPeee is offline   Reply With Quote
Old 03-28-2014, 05:44 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: '61 GMC w/ 65 Chevy Grill & Bumper
That's a 61 GMC Cab..and you have a 64-66 chevy grill..60-66 chevy bumper..62-66 chevy hood. Bumper looks fine to me...does it bend up like that on both sides? If so..then yer fine...here's a picture of mine...its not in the complete stock position..but this is close enough.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-28-2014, 05:54 PM   #3
JayPeee
Yes they both bend up like that on both sides. Thanks!
Didn't realize she's quite the Frankenstein.
Old 03-28-2014, 05:56 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
LOL! Well its a darn good looking truck though!
Old 03-28-2014, 06:10 PM   #5
Bullett
The front bumper on my 62' looks the same. I originally thought something was bent but realized they all look like that.???
Bullett is offline   Reply With Quote
Old 03-28-2014, 06:16 PM   #6
JayPeee
I didn't catch it until I got her home and was like What's interesting is that not all are like that.
Old 03-28-2014, 06:39 PM   #7
NEWFISHER
NEWFISHER's Avatar
That's pretty exaggerated to me. If it was mine I would loosen the upper bolts, remove the lowers and add some body washers or thick alignment shims to the bottom bolts between the frame horns and the backside of the bumper to tilt it back into position.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 03-28-2014, 06:49 PM   #8
JayPeee
You read my mind...that's the approach I was thinking of to straighten it out. Looks like I have a lil weekend project.
Old 03-28-2014, 06:57 PM   #9
96Indyram
96Indyram's Avatar
is it upside down? flip it over...LOL
96Indyram is offline   Reply With Quote
Old 03-28-2014, 07:04 PM   #10
Old Truck Man
Old Truck Man's Avatar
Mine on my 66 trucks don't turn up like that. Also a 63 thru 66 bumper wont fit a 60 thru 62. the 60 thru 62 the frame is wider. something is out of wack to make your bumper not be straighter.
Old Truck Man is offline   Reply With Quote
Old 03-29-2014, 08:58 AM   #11
Bullett
I went out to the garage and took a better look at my 62', my bumper isn't as turned up as yours, yours does seem to be exaggerated, at least compared to mine. The using washers as shims sounds like a good idea. I might do the same to mine.
Old 03-29-2014, 10:09 AM   #12
60-66
60-66's Avatar
Its very common on 60-62 trucks for the front mounting tabs on the front of the frame horns to have either been ripped completely off or bent. Very weak design. Many get re-welded and will be off. This is assuming its still the original 1961 frame. I suggest looking it over there first. 1960-1962 bumpers are the only years that fit a 1961. Yours is up on the sides. Heres how it should look.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 03-29-2014, 11:45 AM   #13
TJ's Chevy
TJ's Chevy's Avatar
Don't listen to what I said.
