Old 03-28-2014, 05:33 PM   #1
sambudo
sambudo's Avatar
68 c10 steering column w/o tilt blinker assy
Can you tell me how to remove this blinker assy from the column?
Is there a trick I'm missing? Do I need to unassembly something that I'm missing?
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 03-28-2014, 11:03 PM   #2
Wrenchbender Ret
Re: 68 c10 steering column w/o tilt blinker assy
Remove the 3 Phillips head screws. You have to move the position of the horseshoe to get to them. You already have the screw to the lever out. The lever can be taken out now.
Wrenchbender Ret is offline   Reply With Quote
Old 04-01-2014, 04:09 PM   #3
sambudo
sambudo's Avatar
can someone tell me when I disasembled my column the aluminum part has what it looks like part of the bearing stuck to it. Are these bearings pressed into this part. Can you tell me if the bearings in the picture do these press in the alluminum peice. Does anyone have pictures of these parts?
Old 04-01-2014, 04:10 PM   #4
sambudo
sambudo's Avatar
Originally Posted by sambudo View Post
can someone tell me when i disasembled my column the aluminum part has what it looks like part of the bearing stuck to it. Are these bearings pressed into this part. Can you tell me if the bearings in the picture do these press in the alluminum peice. Does anyone have pictures of these parts?
Old 04-01-2014, 04:12 PM   #5
sambudo
sambudo's Avatar
are these pressed into the alluminum piece above?
