Old 03-28-2014, 11:37 PM   #1
Billys68SS
Billys68SS's Avatar
66 ReinCARnation
This is a 1966 C10 we picked up today for cheap!
We didn't take the bed. Didn't have any need for it!
When we got it home!
Was last registered in 1989. It actually runs! Needs a carb rebuild... Doing that tomorrow!
1949 GMC PU http://67-72chevytrucks.com/vboard/s...d.php?t=608120
1966 C10 http://67-72chevytrucks.com/vboard/s...06#post6601806
1966 C10 SB Custom Cab, Fleetside, BBW.
1968 Chevelle SS 396
1937 Chevrolet Coupe
Billys68SS is offline   Reply With Quote
Old 03-29-2014, 07:55 AM   #2
rusty76
rusty76's Avatar
Re: 66 ReinCARnation
Cool truck. What's the plans for it?
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-29-2014, 08:10 AM   #3
Billys68SS
Billys68SS's Avatar
Pretty much gonna leave it like it is... Add a flat bed and rebuild the carb and some wheels and tires.
Old 03-29-2014, 05:00 PM   #4
Billys68SS
Billys68SS's Avatar
Laying out the flat bed!
Old 03-29-2014, 07:23 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
Cool! I like that flatbed!!! I'm in for the ride! Looks like its gonna be one good build!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-29-2014, 07:33 PM   #6
kerber63
kerber63's Avatar
The work on the bed looks great, keep it up!
1963 C10 short-wide
Turbocharged 454, T56, 4.11 posi
http://67-72chevytrucks.com/vboard/s...d.php?t=605408
1963 C10 suburban
Unknown, unknown, 3.73 open
http://67-72chevytrucks.com/vboard/s...d.php?t=622037
kerber63 is offline   Reply With Quote
Old 03-29-2014, 08:44 PM   #7
Billys68SS
Billys68SS's Avatar
We made a few changes... Will post some more pics tomorrow. Working on getting all the boards stained right now.
Old 03-30-2014, 09:58 PM   #8
Billys68SS
Billys68SS's Avatar
Tore the carburetor down last night and soaked it overnight in carb cleaner dip can. Rebuilt it today and got it on and running. It will now idle. Still need a little fine tuning, but it runs nicely!
Started staining the bed wood last night. Finished it up early this morning. We chose a color from Rustoleum called Cabernet!
Now bed is finished!
Goal for this weekend met!
Old 03-31-2014, 11:01 PM   #9
Billys68SS
Billys68SS's Avatar
Did a little more work today. Found out that the left rear wheel was missing the drum and the wheel cylinder and hardware were trashed. Also found out that the rear gears are shot. Good thing is I have another rear that is going to get swapped in. Got the old one out before I ran out of daylight. Also found out today that the fuel tank is full of crap. Looks like gas has been in there for 25 years since it was last on the road. This aught to be fun!
Here's a couple pics of the completed bed. Took before dark. Still need to do poly!
Old 04-01-2014, 08:23 AM   #10
1963c-10
1963c-10's Avatar
Nice job on the bed.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-01-2014, 09:21 AM   #11
Billys68SS
Billys68SS's Avatar
Thanks! We took way too long on it, with many changes in between and still a little bit of modifying all the way up to the end! But we are both very happy with how it turned out.
Old 04-01-2014, 11:24 AM   #12
TJ's Chevy
TJ's Chevy's Avatar
Very good job on the bed! I like the color stain you used!
Old 04-01-2014, 11:47 AM   #13
1963c-10
1963c-10's Avatar
That's ok, your getting the quality and fit of want you want in the long run. Looks like the time was worth the wait!!
Too bad your not just a little closer to NC...I have a stack of those drums 3 feet high.
Old 04-01-2014, 01:35 PM   #14
Billys68SS
Billys68SS's Avatar
I'm not really that far from Fayetteville. I'm right on the line near Charlotte!
Old 04-01-2014, 01:37 PM   #15
Billys68SS
Billys68SS's Avatar
Yeah, surprisingly we both like the color as well. I was afraid it would turn out purple, but I think it will be ok. We will see what happens once the poly goes on.
Old 04-03-2014, 07:38 AM   #16
Billys68SS
Billys68SS's Avatar
I screwed up and moved pictures around in my photobucket account. I will repost all the pics ASAP.
Old 04-03-2014, 08:26 AM   #17
Billys68SS
Billys68SS's Avatar
That should have all of them back in here... Now on to last nights progress!
Old 04-03-2014, 08:34 AM   #18
Billys68SS
Billys68SS's Avatar
Rot in the rockers. Typical for these trucks.
Right side...
Everything cut out on the left side and cleaned up.
New piece I made to repair this area...
Trimmed down to fit the cut out area and tacked it place...
Old 04-05-2014, 10:26 AM   #19
Billys68SS
Billys68SS's Avatar
Last nights progress. We got all new wheel cylinders and brake hoses installed, brakes bled out. Sitting on her new shoes!
Old 04-26-2014, 11:53 PM   #20
Billys68SS
Billys68SS's Avatar
Building a filler piece for the left side.
Welded in
Right side rocker damage cut out
Right side repair piece welded in
More repair on right side
Old 04-26-2014, 11:55 PM   #21
Billys68SS
Billys68SS's Avatar
All tuned up! New hoses and belt. Looking good!
Old 04-26-2014, 11:56 PM   #22
Billys68SS
Billys68SS's Avatar
In the process of trying to clean out the fuel tank... I think it's a lost cause and we need to just buy a new tank.
This is the nasty mess that is coming out of the tank! 25 year old gas is pretty disgusting!
Old 04-26-2014, 11:59 PM   #23
Billys68SS
Billys68SS's Avatar
Met up with the guys from the Upstate SC GM Truck Club this afternoon for our monthly meet and greet... Lots of cool trucks and nice people. Got me a sticker and couldn't wait to get it on the truck!
Old 04-28-2014, 10:58 AM   #24
1963c-10
1963c-10's Avatar
Looks like progress has been going good!!
Old 04-28-2014, 11:09 AM   #25
Billys68SS
Billys68SS's Avatar
Thanks... It has slowed down a lot due to time and funding. We are getting a new fuel tank this week and I'm ordering weatherstrip and window gaskets this week as well. Plan to have it ready for a local car show by Saturday. Hopefully get some folks interested.
