03-29-2014, 12:17 AM | #1 |
C20 axle swap from 73-87 1/2ton?
I have searched through the site and havent found an answer to my question. I have a 71 C20 8 lug rear with leaf springs and I am looking to swap in a 5 lug rear (leaf spring) from a 73-87 1/2 ton. Would that be a direct bolt in being both leaf spring? If not what will I need to do to make it work correctly?
12-17-2014, 03:44 PM | #2 |
Re: C20 axle swap from 73-87 1/2ton?
I was thinking about the exact same thing!
Mine's a 72 C20 leaf, thinking about swap a later 5 lug axle in there
1972 GMC 2500 Sierra 350 1971 Pontiac LeMans Sport 400 GTO/Judge Clone 1970 Pontiac GTO 400 convertible restoproject 1970 Pontiac Bonneville 455 convertible |
12-17-2014, 04:04 PM | #3 |
Yes it will work. I had a 14 bolt corporate someone had installed in my 1967 GMC and I swapped a 1973 Chevy truck rearend with no issues.
Scott |
12-17-2014, 04:19 PM | #4 |
1972 K20
I'm pretty sure it's not a direct bolt in project. The 73 and later trucks had staggered shocks (one forward and one back).
12-17-2014, 10:26 PM | #5 |
Sometimes the spring pads have to moved. The shocks have to be rehung. Parking brake cables need reworking. Drive line may need reworking also. It is not a direct bolt in. But worth the swap in strength and parts availabilty
12-21-2014, 12:53 AM | #6 |
Yes your right, sorry I left that out. It does require the shock mount modification.
Scott |
12-21-2014, 01:40 AM | #7 |
The axles are the same width from 71-87. The spring perches are also the same width at 40.5", unless your 67-72 is a 4wd (which the spring perch would be 42.5"). The WMS is also the same at 63.5" from 71-87. The shock mounts will be different on the driver's side if my memory serves me correctly. I cut it off, flipped it around, and welded it back on. It fit perfectly.
12-21-2014, 08:21 PM | #8 |
Other way around. Spring perch centers on a 4 wheel drive 67-72 are 40.5". 2 Wheel 67-72 drive are 42.5" while 4 wheel drive 73-87 are also 42.5". The exception is the 1 ton trucks which are 40.5"
12-22-2014, 10:32 AM | #9 |
I had to move spring perches and shock mounts. Granted I'm talking about a 14 bolt, but it came out of a 79 K20
71 K20 64 GMC mud truck |
