Old 03-29-2014, 11:36 PM   #1
AcampoDave
AcampoDave's Avatar
custom junkyard air filter
I made this from an early 80's C10 housing. First I removed the snorkel to reveal the oval opening in the housing. Then I placed a piece of paper inside the opening and sprayed it from the outside with paint. This made a pattern of the oval which I cut out with scissors and replicated several more times by tracing and cutting on more paper. I then used small pieces of tape to secure my paper patterns evenly around the exterior of the housing and sprayed the whole circumference with a lighter color. After I removed the paper patterns, I cut the resulting stenciled ovals out with my jigsaw. Next, some prep and paint and there you have it an original low buck custom air filter. Later I will order a K&N element specific to the year model of the housing.
AcampoDave is offline   Reply With Quote
Old 03-29-2014, 11:40 PM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: custom junkyard air filter
I like it! It's a cool mix of stock and hot rod. I'll bet it took awhile to get all of the holes cut out and filed to size. You do very nice work!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 03-29-2014, 11:51 PM   #3
BMERDOC
BMERDOC's Avatar
Very nice looking! It'll look even better with the K&N filter installed!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 03-30-2014, 07:11 AM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I like it!! I 2nd the K&N install!! Nice job!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-30-2014, 07:19 AM   #5
bj383ss
bj383ss's Avatar
Looks great. I have a soft soft spot for these factory air cleaners not sure why. I like your deco on the wall too!
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 03-30-2014, 09:31 AM   #6
earl84
Great use of the old air cleaner housing. I have an old one I might need to do that to as well. I bought one of those chrome Edelbrock air cleaners and have decided I would rather have a more stock looking (even though it's not correct) underhood viewing experience.
earl84 is offline   Reply With Quote
Old 03-30-2014, 11:21 AM   #7
TJ's Chevy
TJ's Chevy's Avatar
Looks cool! I'll add to the notion of a K&N filter!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-31-2014, 12:07 PM   #8
donthekawguy
donthekawguy's Avatar
That would match a set of Corvette Ralleys perfectly.
66 shorty
donthekawguy is offline   Reply With Quote
Old 03-31-2014, 12:20 PM   #9
jbgroby
jbgroby's Avatar
I like it, looks great!
jbgroby is offline   Reply With Quote
Old 03-31-2014, 12:21 PM   #10
61K10
61K10's Avatar
you can get a k&n copy from jegs or summit for half the price. for a street rig the filtering should be fine.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-01-2014, 04:42 PM   #11
RANDY COX
RANDY COX's Avatar
Looks good, I took two of those cleaners and made one I cut the snorkel off of one and cut out hole for it and riveted on the other side. so it had two snorkels coming out of the front. Did this on a 72 Blazer 4x4 I used to own...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 04-01-2014, 05:02 PM   #12
MikeN
MikeN's Avatar
Brilliant. Love it!
MikeN is offline   Reply With Quote
Old 04-01-2014, 05:08 PM   #13
WhippinSaw
WhippinSaw's Avatar
nice mod
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 04-01-2014, 07:16 PM   #14
Mathew21
Mathew21's Avatar
Great Job!
Mathew21 is offline   Reply With Quote
Old 04-01-2014, 08:53 PM   #15
AcampoDave
AcampoDave's Avatar
Thanks for all the compliments! Glad you like it. If I inspired anybody out there to make their own, I'm happy. I like to see good old American made stuff get a second chance.
