Old 03-30-2014, 01:50 AM   #1
theredmeadow
Steering column help, pics?
Ok, so now I'm trying to figure out the steering column because I know there's parts missing. the PO didn't know what they were doing so I'm trying to pick up the pieces and make sense of it.
Can you guys tell me what parts I'm missing in my steering column assembly? I've got a 3rd party steering wheel. Here's some pics.
It doesn't seem right. those are the parts that were assembled and so I took it apart and there's definitely missing pieces. Look at that piece of PVC in the center.
Can you guys send pics of what it's supposed to look like and may be some links for parts? I tried looking at different website for everything but I'm not sure what's missing.
theredmeadow is offline   Reply With Quote
Old 03-30-2014, 04:13 AM   #2
Aussie Ol' Blue
Aussie Ol' Blue's Avatar
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
Re: Steering column help, pics?
The bearing in pic1 goes over the shaft in pic 3 and fills the hole and stops the shaft moving about
That white wagon wheel looking thing in pic 2 I dunno what or where.
The grey cast piece is what bolts to your steering wheel mounting plate ( which appears to be missing ) and should sit on top of that white piece. the cancelling cam is missing. There is probably more but I think that's a start.
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY!
IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE!
Aussie Ol' Blue is offline   Reply With Quote
Old 03-30-2014, 01:44 PM   #3
theredmeadow
yeah in pic 2 that plastic thing is a piece of PVC piping that the PO used. I was hoping for pics of completed ones to see what parts I need to order? Lol PVC pipe??? the POs really did a number on this truck.
Old 03-30-2014, 04:04 PM   #4
Wrenchbender Ret
That screw & washer on the turn lever is not going to work. It is up too high & will hit the horn contact ring & blow the horn.
Wrenchbender Ret is offline   Reply With Quote
Old 03-30-2014, 04:41 PM   #5
theredmeadow
I think the PO did something to the horn because the horn doesn't blow at all and lol I don't have anything to push for the horn to blow anyway
Old 03-31-2014, 09:55 PM   #6
theredmeadow
So when I put my steering column back together I must've done something wrong because now my right turn signal flips on when I turn? Also, when I use my turn signal it doesn't turn off after making the turn???
Old 04-02-2014, 08:21 AM   #7
OhioDan
OhioDan's Avatar
This is the only pic I have. Hope it helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
