Old 03-30-2014, 09:19 AM   #1
DANTIP
DANTIP's Avatar
Rear spring sag??
I just purchased this Blazer and think the rear looks like it rides a little low. It does have HD front suspension. Thinking about replacing rear springs and/or adding supplemental air-springs. Any thoughts??
Dan
DANTIP is offline   Reply With Quote
Old 03-30-2014, 10:56 AM   #2
mjjjracing
Re: Rear spring sag??
I think it sits just right , Most Blazers have that stance from the factory and even after you lift them . I would leave it alone myself . Just my 02 cents. Jim , By the way that is a very nice Blazer you have
39 GMC pickup,70 GMC K1500 short bed 4x4 ,72 K10 short bed step side 4x4 ,71 short bed fleet side , 72 K20 long bed ,74 K10 long bed , 69 C30 dump bed dually, 79 K30 standard cab dually , 02 Dodge 4x4 dually
mjjjracing is offline   Reply With Quote
Old 03-30-2014, 11:38 AM   #3
SACRAMENTO 71
SACRAMENTO 71's Avatar
Great find! Love that original look and tone of blue.
68 C10 SWB W/ 72 FRONT CLIP 343SB TH400
64 C10 SWB 406SB TH400
74 SUBURBAN 454BB TH400
78 K10 SWB 350 TH350 6" ON 35" BFG MUD
71 K5 350 W/ TBI 700R4 6" ON 38" BFG MUD
00 K3500 DRW BIG BLOCK "DRINKING PRBLM"
SACRAMENTO 71 is offline   Reply With Quote
Old 03-30-2014, 06:06 PM   #4
DANTIP
DANTIP's Avatar
Thanks! The truck came with crappy-looking body color rally wheels and 12-year old dry cracked tires. I had the white steel wheels with fresh radials from a truck I recently sold. I love the vintage dog-dish caps! I also added my extreme-bend tow hooks. Runs great and the body/paint work is REALLY nice. I've owned many trucks but this is my first Blazer.
Dan
Old 04-03-2014, 12:15 AM   #5
Jdubs71
Jdubs71's Avatar
You could add a leaf to the rear springs to level it out, but when/if you take the top off it might have the opposite affect. Adding a leaf would likely stiffen the ride.
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 04-03-2014, 07:12 AM   #6
DANTIP
DANTIP's Avatar
I bought an air spring system that will supplement the rear leaf springs. I hope to get it installed this weekend and I'll share my thoughts afterward.
Dan
Old 04-03-2014, 10:30 AM   #7
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Looks fantastic.
Helper bags should help, but honestly, for almost 45 year old springs, I would have just replaced the springs.
You'll have to play around with the pressures in the bags, most of the ones I've dealt with you only run single digit pressures when unloaded, otherwise the rear gets really stiff. That may or may not give you the height you want, but it may give you the adjustability you want between top on/off. I.E. 8lbs top on, 3lbs top off, 30lbs when hauling, etc.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 04-03-2014, 10:41 AM   #8
DANTIP
DANTIP's Avatar
I pulled my 1972 Truck Data Book out and after looking at the drawing showing the Blazer dimensions, the stance on my Blazer looks about right. Notice the rear tire is further up into the wheel well compared to the front. Dan
Old 04-03-2014, 10:48 AM   #9
GCncsuHD
GCncsuHD's Avatar
Well also keep in mind, the front fender opening is located noticeably higher on the body than the rear too, so there should be a larger fender gap up front than in the rear like you have.
ΜΟΛΩΝ ΛΑΒΕ
Old 04-06-2014, 08:28 PM   #10
72ironmike
72ironmike's Avatar
Dan
Dan, Looks very nice !
72ironmike is offline   Reply With Quote
