Old 03-30-2014, 02:16 PM   #1
grs
Heat and sound insulation
I plane to install this behind the gas tank, under the dash. Cheaper then the sticky stuff, and probably just as good if not better. I bought it at PepBoys.
grs is offline   Reply With Quote
Old 03-30-2014, 03:33 PM   #2
rideblue00
rideblue00's Avatar
Re: Heat and sound insulation
I'm wondering if that stuff could be used on the firewall and then painted black?
rideblue00 is offline   Reply With Quote
Old 03-30-2014, 09:19 PM   #3
grs
It has aluminum type foil on it. Not sure if self etching primer would work or not.
Old 04-01-2014, 05:00 PM   #4
grs
I put rustoleum self etching spray primer on a piece. Then black paint. It does not flake off when I bend it. Not sure how long it will stay on. Maybe I will just put it under the dash some were, and test it.
Old 04-01-2014, 05:27 PM   #5
grs
Pics of insulation in the truck.
Old 04-01-2014, 06:00 PM   #6
66Submarine
66Submarine's Avatar
What adhesive are you using?
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 04-01-2014, 08:59 PM   #7
grs
Here is a pic of the adhesive. It gets tacky real fast. I cut the material in pieces, and installed them one at a time. I sprayed the body were the piece would go. Then the material. It was tacky in about 30 seconds. Paint thinner or mineral spirits will clean it off you fingers.
Old 04-01-2014, 09:13 PM   #8
LT1 Burb
LT1 Burb's Avatar
That stuff is crap, I have it in my suburban and it doesn't really do anything.
LT1 Burb is offline   Reply With Quote
Old 04-01-2014, 09:50 PM   #9
rideblue00
rideblue00's Avatar
Looks good grs, hopefully it will work the way you want!
