Speedometer cable
Hey Y'all
I need to replace my speedometer cable. Can someone tell me the length of the stock cable to hook up to the 3 speed manual? And regular cable vs metal covered cable? Is it a pain in the ass to remove and replace the cable on the back of the cluster? any advice on the correct way to do it would be appreciated!
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
Re: Speedometer cable
Mines installed so no help with the length. I kept the stock metal one, but used the 74 plastic extension to the transfer case. Small hands help and hopefully the connector is not too tight! Worst case is the bezel only has 3 screws and usually everything has enough slack so it pulls out. It is a tight fit, if you have good paint tape it first. On mine I need to use a thin screwdriver (I have one that goes to a knife edge for pulling wood trim) at the top to get the plastic to clear the dash metal.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
I got my cable and housing at NAPA. It cost $20.50 but I didn't record the p/n. You don't need to know the length, just tell them it is for a 5X Chevy truck. It seems to be longer than I actually needed so it would probably fit a truck with an automatic or even a 4X4. If you only want the cable it will probably come as a universal cable that you cut to length and put the tip on.
got mine from LMC PN# 36-2021 it is 63" long $16.95
Thank you. im deciding between this one, or $10 extra for a metal cable. the $10 is not a factor, I just want to get the better one....
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 Last edited by 57chevyman; 03-30-2014 at 08:01 PM. |
You should be able to walk into your local Napa or other full service parts house and either get one that they have on the shelf or get it with their next stock order from the warehouse without paying the shipping from an online vendor and waiting for up to a week. The quality from the online vendor won't be any higher and to me the metal cable isn't any higher in quality than the plastic one but it may have more of an original look to it.
I guess i thought the black one was metal just with a casing on it. Either way i havnt had a problem with it, plus if it is plastic or just the coating on it less likely for it to rust up and stick.
#8 | |
my current cable is a vinyl outside one, and its cracked about an inch away from where it attaches to the transmission, and from what I can tell, its cracked because the cable is too short by a few inches. I suppose removing the cable I have and measuring it is the first step
