03-30-2014, 06:59 PM | #1 |
CPP Drop Spindles: Conflicting Information
Hi All,
New to the forums and to these trucks. Picked up a '70 C10 SWB last fall. Has a 350/350 combo with a leaf spring rear. Been lurking on the forum since I bought the truck. A great deal of information here! The day I bought it. Done a bit of work to it over the winter. Cleaned up the engine bay, all new brake hoses, rebuilt the drum brakes, new transmission pan gasket and filter, 3-point seatbelts, cleaned up the gauge cluster, new exhaust, new wheels and tires, etc... What it looks like right now. Anyways, I've decided to convert to disc brakes to make it a little safer to drive around town. The wheels are 6-bolt slot mags with 3.25" backspace with drum brakes on all four corners. Being that I like the location of the wheels in the wheel wells now, I had pretty much decided on the CPP OE Drop Spindle Kit with 6-lug rotors PN: 6370SWBK-6OE. They advertise that this only changes the front track width by 1/16" from the drum setup which is fine by me. Here's the issue. From reading on the forum I know that these are a relatively new design (within the past few years). I contacted their customer support to confirm that the track width would not be changed significantly from the drum setup and here is the reply I got... 6370SWBK-6OE “This drops you 2.5 inches and moves your tires out ¾ an inch each side” 6370SWBK6OES “Stock height, same ¾ inch” 6370SWBK-6 “This is the one you want I think. Drops you 2 inches and Moves your tire in ¼ inch, so just a hair less then stock width” 799.00 This kit does not come stock height, I went back and forth with their customer support over email but they could not explain the discrepancy between their own catalog, wheel offset chart (http://www.classicperform.com/Instru...fset_Chart.pdf) and what they wrote in the email. Here's my question: Has anyone ordered this kit (6370SWBK-6OE) and determined what the track width change was from drums? Is the customer service rep just not up-to-date on the products? Any vendors on here that could confirm I would receive the new "smooth" casting spindles? I'm not keen on spending the extra for the "modular" spindles since I'll be staying with stock-size brakes. Thanks for all your help! -Gen |
03-30-2014, 07:21 PM | #2 |
67-72 parts collector,…
Re: CPP Drop Spindles: Conflicting Information
I've been on this board for a long time.
I'm still waiting for this info also. CPP claims to narrow the track width. By how much or compared to what,... I don't know.
03-30-2014, 07:47 PM | #3 |
I bought a complete CPP suspension kit with there modular spindles and my track width changed by about 5/8 of an inch over my stock 71 width
03-30-2014, 08:02 PM | #4 | |
Or 5/8" per side?
03-30-2014, 09:45 PM | #5 |
per side
03-30-2014, 09:54 PM | #6 |
Rob, I'm assuming they brought the wheels in relative to the stock '71 locations? If so, that fits well with the wheel offset chart on CPP's website which shows that the modular spindles should move the wheels in 3/4" per side relative to the stock '71 disc setup. Thanks for the input.
03-30-2014, 10:02 PM | #7 |
That is correct the wheels moved in relative to the stock location
03-30-2014, 10:05 PM | #8 | |
TNT-MOTORSPORTS
This is what we experienced too . Modulars "do narrow track width" compared to stock disc or drop spindles. We did this conversion from standard CPP Drop spindles to Modulars , gained about 1''-1-1/8' per side . 6370SWBK-6OE “This drops you 2.5 inches and moves your tires out ¾ an inch each side” . This is correct as well, to my knowledge all disc spindles (other than CPP modulars) will widen the track width of a "drum brake truck" to the width of a 71-72. And Yes I sell CPP. Last edited by ksbrktracer; 07-13-2014 at 11:34 PM. |
03-30-2014, 10:07 PM | #9 |
Keith,
The wheel offset chart linked above seems to be clear. For 63-70 C10's they list the change "from drum" and for 71-72 C10's they list the change 'from disc'. Rob's experience above suggests that the numbers listed for the modular spindles, at least, are close to reality. The issue, of course, is that their customer service rep does not agree with the chart for either model of spindle. Any chance someone has bought the smooth cast 'OE' spindles with built-in caliper mounting ears (PN: CP4SX) and has measured before and after? |
03-30-2014, 10:14 PM | #10 | |
1) Drum brake fronts have the narrowest oem track width. 2) stock oem 71-87 disc brake spindles are suppose to be 3/4" wider than oem drum brake spindles. 3) old school drop spindles are suppose to be 1/2"-3/4" wider than stock disc brake spindles. (for tie rod and lower a-arm clearance, due to raising the spindle centerline) Where do the CPP modular spindles track width fall in? Ok,... suppose they are 5/8" narrower (per side) than stock disc brake spindles. That makes them 1/4" WIDER (per side) than drum brake spindles. Correct? But yet CPP still just claims they move the wheels in. If I had all the different spindles,... I would make a jig to put this issue to rest. Seems like CPP could do this,... but they don't.
03-30-2014, 10:18 PM | #11 | |
I have a radical idea!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
03-30-2014, 10:20 PM | #12 | |
No one has ever put this info out with pictures of the direct comparison,... and actual numerical differences..
03-30-2014, 10:23 PM | #13 |
TNT-MOTORSPORTS
Before I ordered them we point blank asked ..... What are they going to do to the truck. They said about 3/4" narrower than stock disc and about a 1/4" narrower than stock drum. He did go onto say that ride height , alignment etc can effect actual measurements as well .... which I agree with.
All of that being said ..... The truck was almost undrivable with the standard CPP drop disc spindle on a 67 and a 20X8.5 wheel with 4.50'' backspacing. Switching over to the CPP Modular spindles did pull the wheel in what looks like right at 1''-1-1/8'' of an inch . And the truck became drivable changing absolutely nothing but the spindles. Last edited by ksbrktracer; 07-13-2014 at 11:37 PM. Reason: updated info |
03-30-2014, 11:12 PM | #14 |
I think that's the one sentence everyone has been looking to see but I've never seen anything where CPP plainly stated that. I think that's the reason for the 2.0" drop and not 2.5" to compensate for the rod ends and control arm issue. Looks like they may have moved over to this spacing in all their spindles. They have been advertising the "New Design" for their 2.5" spindles recently.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
03-30-2014, 11:23 PM | #15 |
Good info here thank you guys for posting it. Sticky thread
Scott |
03-31-2014, 12:38 AM | #16 |
I went from 6-lug drum to 6-lug modular cpp disc. I highly recommend going with the modular setup if you plan on dropping it. I run a 10" Wheel with a 255 tire up front and I have no real issues except wheel weights hit my control arms when turning. If I would of went with stock drop spindle setup my tire would be sticking out my fenders.
03-31-2014, 12:44 AM | #17 |
Here's how my tires sit. This is Modular Drop Spindles, 3-Inch Drop Coils, and a sway bar. I'm fairly sure without a sway bar my truck would sit a little lower in front. 10" Corvette Rally Wheel, 255/60/15
03-31-2014, 10:55 AM | #18 | |
1967 swb 454 cid 700R4 trans SOLD 2006 Chevy Trailblazer SS 2013 Camaro RS convertible the wife's Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248 |
03-31-2014, 11:20 AM | #19 |
That's a awesome looking truck Big D! Just checked out your build thread.
Scott |
03-31-2014, 11:31 AM | #20 |
That figures up to 1.22" per side narrower.
03-31-2014, 12:12 PM | #21 | |
That measurement is give or take a little, hard to measure it exact on the tires. i know it made a big difference.
03-31-2014, 12:15 PM | #22 |
VA72C10
did you switch from drums or another brand of drop /stock spindles?
Looking for a 67-72 swb or blazer project in or around VA. |
03-31-2014, 12:18 PM | #23 |
That measurement was going from a 2 1/2inch aftermarket drop spindle to the CPP modular. Also want to add the CPP modular is listed as a 2inch drop it more like 2 1/4 inch.
03-31-2014, 01:00 PM | #24 | |
That's what I'm trying to get figured out.
03-31-2014, 04:56 PM | #25 |
I don't believe a thing CPP has to say
