Originally Posted by dojo
Shouldn't we have 12 volts at the oil and water sending units also??
No, that's perfectly normal for your test light to be dim when connected to the sending unit wires of either the water temp or oil pressure gauges. That's due to the internal resistance of the coils inside the meter. In fact, having a full 12V present on the sending unit wire can potentially damage the sending unit.
We have good grounds, actually all the gauges are grounded in the same place.
What is the location of your ground point?
The sending units ground via their threaded connections into the engine. So for proper operation, you need to have a good ground connection from the engine to the GND terminal on the back of the Autometer gauge.
