Old 03-31-2014, 09:22 AM   #1
steved033
Greetings from Atlanta
Hey everyone,
I just joined up because I've had a '66 fleetside longbed for a couple months now.
The truck was a light blue 250/3 on the tree that became dark green, that became flat black, and a 3 on the floor conversion. I've been going through things and making them better. The dash was a non-gauge, and most of the bulbs were burned out (that's another thread, as I put aftermarket 2" gauges behind the glass), the wiring was a disaster, the fuse block had bits of copper pipe instead of fuses, extra wires were run around inside, there's no turnsignals, and it runs hot. I thought the hot running was the thermostat, but that doesn't seem to be the case.
Plans are to build something custom, 5.3 swap, auto, airbags....
anyway, thought i'd say hi!
Steve
steved033 is offline   Reply With Quote
Old 03-31-2014, 09:48 AM   #2
flashed
Re: Greetings from Atlanta
Welcome from Canton ,check out the n Ga section .
flashed is offline   Reply With Quote
Old 03-31-2014, 11:18 AM   #3
steved033
awesome...did.
sjd
Old 03-31-2014, 01:10 PM   #4
Mathew21
Mathew21's Avatar
Welcome, Post some pictures when you get a chance.
Mathew21 is offline   Reply With Quote
Old 03-31-2014, 01:17 PM   #5
MikeS.
MikeS.'s Avatar
Yep we need pics, lots of pics. Ohh and Welcome!
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 03-31-2014, 01:41 PM   #6
steved033
Here's one from the day I got it. I traded a 1968 Plymouth Fury Convertible for it--even trade....not sure who got the better deal, but man, it's easier to find parts for this thing. I included a pic of the Fury, too. I had no room inside for it, and it had no roof...
The truck is solid. Someone welded a piece of diamond plate in the bed, and it's not fastened down in the corner that looks saggy in the picture. the frame is straight and solid.
The chevy is cool, I don't think the water pump is pumping...that'll be this coming weekend's project. It'll pass 230 degrees, there's a new thermostat, and there's a weird rattle that isn't pushrods or bottom end near the fan... I have a new pump and radiator...we'll see.
sjd
Old 03-31-2014, 01:48 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Nice looking truck! Does sound like you have a water flow issue. Hope yer able to easily fix it. And welcome from Oregon! T.J.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-31-2014, 04:26 PM   #8
Old Bleu
Old Bleu's Avatar
Hi Steve, I'm out beyond Loganville. I've only had my '64 since last May, but if you need any help, don't hesitate to ask. This folks on this forum can answer any truck questions that you have for sure.
Old Bleu is offline   Reply With Quote
Old 03-31-2014, 11:34 PM   #9
Jeff La
Welcome to the forum and nice vehicles.
Jeff La is offline   Reply With Quote
Old 04-01-2014, 12:22 AM   #10
Captainfab
60-66 Nut
Welcome to the forum Steve
Old 04-01-2014, 07:57 AM   #11
steved033
Thanks for all the welcomes, everyone!
I'm a car guy (i'm bad at sports) the fleet also includes a Datsun 240z, an Austin Healey, and a 1971 Plymouth GTX. I'm a year away from 40, i'm pretty good with carburetors (esp. SU's), I found my niche and I'm enjoying every minute of it.
sjd
Old 04-01-2014, 08:39 AM   #12
1963c-10
1963c-10's Avatar
Welcome and great looking project. Had a buddy growing up who was big into GTX's...spent quite a few nights cruising the blvd in them.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-01-2014, 09:39 AM   #13
flashed
Show us pics of your other toys too ,especially the GTX .
Old 04-01-2014, 09:49 AM   #14
steved033
okay... BMW, 240z, and GTX...ford focus commuter in the background
Old 04-01-2014, 10:16 AM   #15
Jeff La
Allright don't be stingy where's the austin LOL
Old 04-01-2014, 10:50 AM   #16
steved033
JEEEZ!!!! LOL. I found it in a carport in Atlanta. it had sat there since 1968. I had it running in 20 minutes, it's run pretty much perfectly since then. 49k miles.
I've got the knack to hunt barn find cars...I just don't have the capital or space to buy them all.... I've passed on several '78 T/A's (I want a solar gold SE or Martinique Blue so bad!!!), chargers, alfas, man...the stories...
sjd
Old 04-01-2014, 01:36 PM   #17
markeb01
Senior Enthusiast
markeb01's Avatar
Nice collection. Welcome! Looking forward to the truck progress.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-01-2014, 11:12 PM   #18
Jeff La
sjd
Well should you find a mint 58 chevy pickup you don't have the space for, I'm willing to help out
Also thanks for the pics
I guess my wife will have to go visit her cousins in Atlanta
Old 04-07-2014, 08:23 AM   #19
steved033
I'll keep an ear out for that '58...
I should probably start a build thread. This weekend, I set the timing correctly, adjusted the carb, and did a couple laps around the neighborhood. Oil pressure is low...about 20 psi when running, but when hot, it drops to 5 psi at idle. I pulled the plugs to check them, I was worried as there's a miss and as there's definitely some blowby coming out the vent, 1-5 are perfect. #6 is oily and gunky...well, I thought, that explains that tiny little miss...I cleaned it up, and now that everything is tuned in, and not overheating (the truck had WAY too much advance...) i'll see what happens.
sjd
Old 04-07-2014, 11:38 AM   #20
jhrusk
welcome
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
