03-31-2014, 10:33 AM | #1 |
66 short in Australia
gday...starting a build thread after lurking for a while.building a 66 short fleetside,small window here in Australia.i have been mainly into drag's for years,but last project is a daily driver and truck will be too.bought truck before xmas and have been working on it over summer.here it is when i got it.truck came from Idaho 9 years ago,has had 2 other owners in that time.2nd guy repaired floor's,had new side glass cut and purchased new door/window seals.cleaned untreated weldswith vinegar,than wire wheeled area,then treated with fish oil.
03-31-2014, 10:43 AM | #2 |
Re: 66 short in Australia
started with front bumper.welded up a few deep scrapes,filled a few low areas than into epoxy.front panel next.stripped 3 old paint layers,no real rust,just lots of crap on the back.sand blater cleaned it up.[IMG][/IMG]painted back in satin black...front left in epoxy
03-31-2014, 11:06 AM | #3 |
radiator support panel was ok for rust..bit beat up on drivers side where it meets inner guard,maybe small collision some time?.....painted in satin black also.moved onto guards/fenders.truck came with an extra pair of guards...so picked best 2 out.had to repair bottom of pass side including brace,but not too bad.pretty clean on the inside..both guards had a good coat of black than green primer/paint that seemed to protect thembit of filler to straighten them outthan into epoxy[IMG][IMG][IMG][/IMG][/IMG][/IMG]
03-31-2014, 11:27 AM | #4 |
[IMG][/IMG]painting under carportdoors next..no rust,just numerous mirror holes to weld up.that brings me upto this week.stripping bonnet/hood.little rust in front,small dents on sides.
03-31-2014, 11:56 AM | #5 |
have collected a few bits for truck also.have a set of 15x8 blazer wheels with centre caps and dress rims,speedway motors ram horns,got a 1960 Buick airfilter and a pair of script Chevrolet valve covers.under bonnet inspired by Delmo and Dino.truck will be small block/t700...keep 12 bolt rear.left hand drive is legal here if vehicle is more than 30 years old..but must remain pretty stock..including drum brakes!i have been chasing a set for a while and think i have a couple of leads now..previous owner had put Australian stubs and 5 stud dics/calipers onto front..weather is changing here..start of autumn/fall already so getting cooler and can expect a bit of rain.try to get bonnet stripped and epoxy this week..then start on cab.no rust repair to speek of,but a few dents,mainly on the roof from farm use.as long as we get a month/6 weeks of decent weather,painting will be ok.if it gets too cold,i will concentrate on the chassis.couple pics of my other carsdaily driver was my last project..1974 holden HQ..ls1&4l60e.colour is original called sunburst gold.the HQ model was the highest selling car in Australia..avaliable in 4 door sedan,wagon,panelvan, ute and 2 door monaro's.drag car i am halves with my brother..1983 commodre..750hp BBC/glide 9.7's on 1/4mile...currently getting new front halve after brush with concrete wall.cheers
03-31-2014, 04:14 PM | #6 |
Welcome to the show. Looks like you know what you are doing. Can't wait to see more.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
03-31-2014, 07:52 PM | #7 |
You're doing some really nice work, Buzz! I really like your HQ. It reminds me a lot of our '70 Chevelles we have over here in the States. The color (Sunburst Gold) looks a lot like the original color my '71 Camaro Rally Sport had originally, which was called Placer Gold. Does your color have metallic in it? They had two versions in the States, one was metallic and the other was a solid.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
04-01-2014, 08:28 AM | #8 |
Very cool build....nice progress.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-01-2014, 09:14 AM | #9 |
gday...trying my best here guy's....learnt alot from other's builds on here...helps alot seeing as these trucks were never sold here!sunburst gold is a light metallic and hq is similar size to similar year nova.even looks like a right hand drive nova under bonnet
04-01-2014, 11:26 AM | #10 |
Nice work!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-01-2014, 02:29 PM | #11 |
It is awesome to see all the bad ass rides coming out of Australia. Keep up the good work.
1964 swb bbw body drop on 22s ls swapped c10 build.. http://67-72chevytrucks.com/vboard/s...d.php?t=617623 |
04-01-2014, 03:25 PM | #12 |
Is it just me, or was anyone else bummed as hell when they realized that the Mad Max movies were about him, and not the "Last of the V8 Interceptors" ???
I didnt care so much for the trails Max went thru, I cried for the car.... Sadly that movie and its sequel really put in my mind that Australia had the nads for hot cars !!! Good to see you guys living up to that perception
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
04-10-2014, 05:28 AM | #13 |
worked on bonnet this week..1 decent dent that i had to dolly,than skimmed with filler.cleaned behind blinkers and "nostrills"lots of dust and crap but came up pretty good.masked off and painted black...top will get epoxy on the weekend than will take it off and clean underside..cheers
04-11-2014, 12:05 AM | #14 |
60-66 Nut
You're doing some nice work.......of course it is no surprise looking at your other rides.
It is ironic that I am reading about a truck being built in Australia, that came from Idaho
04-12-2014, 05:27 AM | #15 |
gday..got bonnet into epoxy today..looks okay.also got inner guards,heater,wipers and dash wiring out.few leaves and general crap inside heater.looks like motor/fan no good...fan spins on the shaft.
04-12-2014, 05:29 AM | #16 |
[IMG][/IMG]
04-12-2014, 05:31 AM | #17 |
firewall very solid.just cleaning crud off lower sections.seems to have a few coats of paint,,but original blue still underneath. |
04-17-2014, 09:20 AM | #18 |
gday..underside of bonnet painted satin black today.might go back a fill a couple of spots...starting on door jams,
04-17-2014, 09:30 AM | #19 |
Looking good.
04-17-2014, 12:20 PM | #20 |
Nice one Buzz.... have to say you are the first on here from Mt Gambier.....!! Look forward to following along.
04-22-2014, 11:23 PM | #21 |
gday..been working on roof over the weekend.got paint stripped,repaired 2 dents in rear section,cleaned out all the old seam sealer.
04-22-2014, 11:28 PM | #22 |
do people seam seal over these joints around firewall and window?my truck had plenty on the roof and door jams..but nothing on firewall? |
04-25-2014, 02:47 PM | #23 |
I like what you are doing with your truck.
I am an aussie living in the USA (for 10 years), I have a 65 C10 project, as well as a ton of other ridiculous stuff in my garage. Is it difficult to buy paint and primer in Oz? I seem to recall it was hard to buy pro stuff if you did not have a business but please forgive me if I am wrong - it has been a long time since I lived there..... I need to move back soon so my wife and children can gain their citizenship's before the kids get too old. |
04-25-2014, 03:06 PM | #24 |
If you can seam seal it, I would.
04-25-2014, 08:27 PM | #25 |
gday...seam sealer going on today..also got 17 holes welded up on firewall yesterday.
Far Kennel--i have a couple of supply shop here in town..1 has Autothane brand,made by PPG and seems quite reasonable.got quoted $550 for 4lt kit of high build and 4lt of basecoat/clearcoat...just have to chose a colour!been thinking hugger orange or matt grey or OG blue or turquoise poly? |
