70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Need some Help with Fitting
This vacuum connector is from the stock factory intake off my 396. The vacuum line from this connect goes to my transmission. What I'm looking for is a connector like this with 2 ports coming off it so I can hook up my dash vacumn gauge. I was hunting around this afternoon at Napa and a couple of other places but no one has anything like this available. If anyone knows where I can get one like this with 2 ports new or used let me know. I know I can use piece of rubber with a T fitting and run both from that but I'd like to have the dual port OEM fitting. The thread is 3/8's.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: Dec 2013
Location: Fort Mitchell, AL (out the back gate of Ft Benning)
Re: Need some Help with Fitting
will have to look in my bins, but I think I have one
SSG Walker Harris '72 Cheyenne Longbed '66 Panel '66 Short Stepside '65 Short Fleetside |
any local autoparts stores carry common autoparts like that
I went to Napa and 2 other parts places today and they aren't even listed in catalogues.
I'll owe ya if you do.
Go to the local junkyard. Look on ford motors.. Very common to find multi vac trees on them.
![]() Join Date: May 2006
I bought mine at a corvette restoration parts house, think it was corvettes across america. They have two, three, or four hose barbs, and the oem threaded fitting for your brake booster. LMK if you need more info.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
![]() Join Date: May 2010
Go to www.corvettecentral.com and search all years for "vacuum fitting" and you'll get a bunch of choices. Take your pick. I believe the trans port is unique. Pick one with that, then decide on the other port.
did you look on the shelves? around here they are in the help sections// heck we've also got them at ace hardware store
![]() Join Date: Jan 2010
I probably have one on the shelf. Ill confirm tomorrow but its yours if you need it.
Thanks Rod
Summit Racing carries them.
#13 |
Hey Greg I have 3 but they are all single port. sorry I couldn't help out.
#14 |
I bought mine on Ebay.
-Jason USN Retired |
#15 |
member #16
![]() Join Date: Dec 1999
Here's some more.
https://www.paragoncorvette.com/c-22...-fittings.aspx
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#16 |
Thanks anyway Rod..
