03-31-2014, 07:51 PM | #1 |
replacing cab mounts
Mine are in rough shape.. I see theres a couple of different replacement ones out there.. what did you guys use . Can you get New bushings for them? How hard of a job is it.. I will also try replacing the rest of floor that is rusted.. thanks
04-08-2014, 08:36 PM | #2 |
Re: replacing cab mounts
once you lift the cap off the frame its just slidding the new ones in, the hard part is get the cab up and supported!!! i have a C10 so its just the cab and not a full body like you have. get plenty of helpers or use plenty of jacks that can support the weight as close to the mounting points to spread the load as if it were still on the frame. im in detroit so if you need a hand i down!!!
04-23-2014, 12:13 AM | #3 |
Thanks... its a slow going process and haven't pulled the trigger on fixing the floors and cab mounts...
04-23-2014, 02:29 AM | #4 |
whats the hold up? the summer is coming im sure u wanna b cruising down woodward
04-23-2014, 07:32 AM | #5 |
Hey Webby, I just did an airbag job on my Panel. I had to loosen and lift the body in order to the do the c-notch properly.
What I did was remove the bolt on the steering column and separate from the splines, right above the steering box. Then I removed the linkage on my automatic tranny. Loosen the body bolts all around the body and jacked it up side by side patiently. You might need block spacers between the jack and body to get high enough. I'll tell you right now though, them rubber body mounts are not in the market. You will not find any replacements, at least I didn't. Mine were still usable and didn't replace them. Just by looking at those pics, you WILL be breaking them rusted bolts. The cab bolts are a little thicker. Plus you have a pair of bolts up front on the radiator support. Good luck.
"El Jerry" '03 3500 Duramax dually '96 1500 ext. cab Chevy '66 swb C-10 '63 Panel '60 VW vert '56 VW vert |
04-24-2014, 06:50 PM | #6 |
Ive been rolling it like this around the city a little bit... it looks like the replacements just slide over my originals? Where are you located pimp?.. im in process of switching to discs up front and pancaking the front cross member... maybe I should tackle these at the same time. I see there's a couple different styles of replacements
05-01-2014, 08:24 PM | #7 |
i have two spots one in detroit, and the other is in taylor. taylor is where my frame and body panels are, and detroit is where i do my rehab of smaller parts whats up?
05-02-2014, 09:25 AM | #8 |
ima be around hodges subaru round 11 today, maybe i can see ur build a give a hand or two
05-04-2014, 11:02 AM | #9 |
Sorry for the late reply.. I'm not on here all the time... Its hard for me to find Time/place to work on it with living at an apartment... should be renting a house soon.. then sparks will fly.
05-04-2014, 11:16 AM | #10 |
well just send a PM anytime ur free to work on it and maybe we can set something up
05-06-2014, 08:40 AM | #11 |
Ell yeah... hopefully I can get this cross member sectioned this weekend.. ill let you v know.. ill supply drinks and pizza.. .
