Old 03-31-2014, 08:16 PM   #1
8door
Not too old to learn
Question Gas guage only registers 1/4 full
Installed new fuel tank sender, hoping to fix the 1/4 tank thing.
Nope still only 1/4 after filling to the top.
Do I need to bend with the the float rod or could the problem be the guage?
The guage doese move down after about 2 gallons are used but there it sits at
the 1/4 mark.
Help !
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 03-31-2014, 08:29 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Gas guage only registers 1/4 full
the 1/4 mark.
Help !
Remove the ground from the sending unit and turn the key on. The gauge should go past full about the 3 o clock position. If it does not, I would suspect the gauge is sticking and won't move past the 1/4 mark.
It seems odd to me that you changed the sending unit to correct the problem and still have the same problem. I would not bet on the float being in the wrong position. It is possible but not likely.
Let me know if you need a gauge. I have some in my inventory.
Thank you,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 03-31-2014, 08:41 PM   #3
8door
Thank you,
Tom
Tbone thanks for fast reply, I'll do that ground disconnect and get back.
Old 03-31-2014, 09:00 PM   #4
duckdude
I cant get mine to work at all even with new sending unit. brown wire from tank to fuse box is good. tank is grounded good. im about to pull my hair out.
duckdude is offline   Reply With Quote
Old 03-31-2014, 09:07 PM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
Do you have a 12V test light or a DVOM? Have you checked to see if you have power to the gauge? If the gauge is not doing anything at all then it is most likely not getting power to the gauge. Check for power right on the gauge studs with the key in the run position but not have the engine started. Also check for a burn spot on the printed circuit board on the back of your cluster.
