Fender gaskets
Where can I get a set of the gaskets that go between the inner and outer fenders at the rear of the top of the fender. and also I saw a set of gaskets that go in between the inner fenders and the the core support and was wondering if anyone had a diagram of where those go.
#2 | |
Re: Fender gaskets
#3 | |
Re: Fender gaskets
![]() Join Date: Aug 2013
Re: Fender gaskets
LMC and classictrucks sells the all the gaskets also
Re: Fender gaskets
I looked on the LMC and Classic industries web sight for these two but could not find anything does anyone have a part number for them?
Re: Fender gaskets
i have both books on hand i will send the part numbers
Re: Fender gaskets
38-7448 inner fender seal set chevy gmc 60-66 $9.95 these are the (A) shaped pieces you cut to fit and either glue or staples like factory.
38-7447 front fender seal set 2-pcs chevy gmc 60-63 $5.95 38-7749 front fender seal set 2-pcs chevy gmc 64-66 $6.95 these parts go on the closing panel and are yr matched this is LMC..... ClassicParts front fender seal $6.95 37-613(60-63) 37-614(64-66) inner fender seal 37-729 $14.95 hope this helps |
Re: Fender gaskets
lmc page 10 spring edition cbe.50
Re: Fender gaskets
same page
Re: Fender gaskets
classicparts vol9 page 32
Re: Fender gaskets
That helps allot thanks. I did not realize that it is supposed to be cut and used for both the inner fender to the firewall and the outer fender to the inner fender. How about the gasket in the top circle in the image?
Re: Fender gaskets
ive only seen pics of a flat foam piece black in color and not sure if its for sell anywhere i will send a pic ina bit
#13 |
Re: Fender gaskets
heres the only pic ive ever seen of the gasket
#14 |
Re: Fender gaskets
maybe insulation sheet or something flat and black foam will work
#15 |
Re: Fender gaskets
Bowtie bits
Live and let live ![]() |
#16 |
Re: Fender gaskets
Grate sight. I saw all the gaskets except this one. Am I just missing it?
#17 |
Re: Fender gaskets
i think were gonna hafta be creative on that piece
#18 |
Re: Fender gaskets
Can anyone tell me where these are supposed to go?
#19 |
Re: Fender gaskets
Sorry forgot the photo
