Old 04-01-2014, 12:08 AM   #1
tim21391
tim21391's Avatar
1969 k10 coming home
Well, thought it was tie to mention to fellow 67-72 owners that I finally am going to have a big brother to my 72 c10... A 69 k10 popped up for sale $1200. Lifted 8" 35" tires late 90s vortec motor with carb setup.. Four speed. Everything runs and works.. Needs shocks all way round since it was lifted.. Since rear end mounts under the leafs the ubolts need to be changed since it's loose when the round bolts are tight... Exhaust is rigged up but some headers with header iff let's will fix that.. Truck was $1200 and I plan on spending no more then $500-$700 on parts.. Cabs rusty in common areas both shafts are too small... Fix mechanical issues then I'll be hitting some mudholes!!! This guy is back in action again... The 72 and 69 will look good sitting next to each other I driveway
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-01-2014, 12:12 AM   #2
tim21391
tim21391's Avatar
Re: 1969 k10 coming home
And it does come with a bed same color
Old 04-01-2014, 10:11 AM   #3
I like the one of each approach. One for every occasion,I've always said. You did good on that! I would have been scratchin' for twelve bills real quick if I saw that.Have fun with it.
Oh...Need picture of both trucks together or I'm requesting this thread be deleted.
