04-01-2014, 12:28 AM | #1 |
Th400 trans question
I have a 69 350 with the th400 trans it has the cooler built into the radiator I line that goes to bottom and one to top then back to the trans. My question is the top line on radiator goes to were on trans top or bottom and then bottom on radiator goes were on trans I think I have them reversed
04-01-2014, 08:12 AM | #2 |
Re: Th400 trans question
On a TH400 (or 350) the cooler fluid flow is: lower trans. out, lower radiator cooler in, upper radiator cooler out, upper trans. in.
http://67-72chevytrucks.com/vboard/s...d.php?t=570899
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
