Old 04-01-2014, 01:56 PM   #1
67stepper
67stepper's Avatar
rear sway bar pics wanted.
Cant find very many pics of how to properly mount a rear sway bar. I'm looking to install a matching 1 1/8th inch rear sway bar to my 67. Id like to see where it attachs to the frame? Not looking for the fancy rear sway bars just the basic style.
67 longbed fleetside switching to a 67 shortbed stepside with a 71 front clip, front disks, 2.5" lowering spindles w/1" lowering spring in the front, 5" lowering spings w/1" lowering block rear, 255/6015 front and 275/60/15 rear on 15x8.5 slotted mags, 355/350, 12 bolt 4.11 posi.
67stepper is offline   Reply With Quote
Old 04-01-2014, 05:02 PM   #2
oldman3
oldman3's Avatar
Re: rear sway bar pics wanted.
Here's a couple pics from one I did a few years back. It's on a 67 LWB step side with trailing arms. First pic is kind of a side/top shot and the second is back/bottom shot. Got the bar and brackets from CPP....Jim
oldman3 is offline   Reply With Quote
Old 04-01-2014, 07:24 PM   #3
67stepper
67stepper's Avatar
Thanks, was it a full bolt on kit or did you weld the side brackets to the frame?
How did you determine where to mount it?
Is there a correct location?
Old 04-01-2014, 07:29 PM   #4
oldman3
oldman3's Avatar
It is a full bolt on kit, I welded it to the frame, but can be bolted. Instructions told how to mount, and which holes in the frame to measure from, pretty straight forward...Jim
Old 04-01-2014, 07:48 PM   #5
67stepper
67stepper's Avatar
http://www.classicperform.com/Instru...DF/CPP7401.htm (click on the download instructions to get it to open)
and another one. http://www.classicperform.com/Instru...PDF/CP7401.htm
Thanks i found them finally.
