07-27-2003, 02:25 PM | #1 |
91 SWB 383
drop trucks
who all still running 15x10 rims on there truck that has a flip kits . was wonder if they have a problem of it rubbing .
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040, http://photobucket.com/albums/q169/k...ahoe prostreet |
07-27-2003, 02:37 PM | #2 |
20x10's w/no probs. I do have some 15x10 steelies but the tires are flat so I haven't mounted them on the truck.
07-27-2003, 03:34 PM | #3 |
91 SWB 383
i just want to make sure it don't rub . i'm running 15x10 and 295/50/15 . the back has a flip kit . i don't want it to rub . try to use the wide tire i can .
07-27-2003, 04:09 PM | #4 |
What offset do those wheels have? 5" would be just about right.
07-27-2003, 04:26 PM | #5 |
91 SWB 383
15x10 4.25
07-27-2003, 05:25 PM | #6 |
That prob puts the tire real close to the outer fender lip. You might have to roll the lip for clearance.
07-27-2003, 05:30 PM | #7 |
91 SWB 383
i was just measure the tire and rim . the total back spacing was 5. that with the tire . i'll sell them before i do that . lol the front i put 15x8 with 205/65/15. should be no problems . i met just and have my rear end narrow . it only cost 150.00 at JAB hot rod shop .
07-27-2003, 05:33 PM | #8 |
Seems like it would be easier to get wheels w/the exact back spacing you require. A 10" wheel will fit w/o the hassle of narrowing the axle.
07-27-2003, 05:36 PM | #9 |
91 SWB 383
let me know when u go to red line and i get the guys to ride now there to meet up with u . i need my truck dack so i can test fit the rims on it . it was going to get from the paint shop fri but the shop never open so i don't know it it done yet .
07-27-2003, 10:20 PM | #10 |
Depends on backspacing just as other members suggested. I ordered Torque Thrust II's with standard offset and the tire rubbed the bed, not the outer lip. ARE built me a set of custom rims with more back-spacing to push wheel away from bed. I've also run 9.5" and 10" with no problem. My set up is a 275, 60, 17, but moving to a wider tire soon.
07-28-2003, 12:15 PM | #11 | |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
07-28-2003, 09:44 PM | #12 |
10's will not fit with incorrect backspacing, print out the instructions on how to measure for offsets before ordering. Again, my 9.5" rubbed the bed, not the lip. If your backspace is too great, you'll rub fender. Anyway, do the homework and save yourself some and frustration.
07-28-2003, 10:44 PM | #13 |
I have 17x9½'s with a flip kit. I used 5½" BS and it works out perfectly..in fact, I prolly could have went with 5", and I'd still be ok...
07-29-2003, 07:20 PM | #14 |
91 SWB 383
tire and wheel comb has 5" bs . the back clear fine . it the front i'm worry about . the rim is 4.25 bs . they r a true 10 wheels
07-29-2003, 07:31 PM | #15 | |
07-29-2003, 07:35 PM | #16 |
91 SWB 383
i have 15x8 on front and 15x10 in back . they r cagers streetlight
07-29-2003, 11:40 PM | #17 |
mine dont rub and im running 15x10 295/50r15 and i got a flip kit
07-30-2003, 06:56 PM | #18 |
STILL PLAYS WITH TRUX
I've got 15x10x4.5 b/s and im running a flip kit and 275/50/15 rear and 265/50/15 front.
I've got a stepside bed and i think the rear wheel well size's are differant from that of a fleetside bed. Stepsides having more room. But i did roll the front fender lip in cuz if i hit a dip or pot hole hard enough the tire would come up and contact the lip and the tire side walls would get sliced. |
07-30-2003, 08:49 PM | #19 |
91 SWB 383
thanks guys
