Old 04-01-2014, 08:52 PM   #1
Brian4618
Brian4618's Avatar
Will radiator listed for 6cyl work in with my v8 ?
I've found a radiator and electric fan kit for sale on eBay, seem to have good reviews on here and eBay, but its listed for a 6cyl truck. The seller told me it would work but to check to make sure I dont have a heavy duty radiator with a thicker core now and to confirm the dimensions he provides match what I have. I no longer have the original radiator to measure, can anyone help me out? It's a 72 k10 with 350, it has automatic trans but I'll probablly run a seperate cooler so that shouldn't be a issue either way. Here's the eBay listing-http://m.ebay.com/itm?itemId=191007606143
Thanks, Brian
Brian4618 is offline   Reply With Quote
Old 04-01-2014, 09:28 PM   #2
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Re: Will radiator listed for 6cyl work in with my v8 ?
Some sellers use the measurement as a one size fits all type deal , I got an alluminum radiator off ebay and works perfect and would cool a big v8
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 04-01-2014, 09:38 PM   #3
Brian4618
Brian4618's Avatar
Ok thanks! I'll go ahead and order a it!
Old 04-01-2014, 10:45 PM   #4
brian1971
brian1971's Avatar
I just ordered a aluminum radiator for my truck and the ones for the 6cyl are narrower than the V8 ones be careful don't order the wrong one and have to pay to ship it back.
If you need the measurements off mine let me know.Brian
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 04-02-2014, 07:40 AM   #5
Brian4618
Brian4618's Avatar
Ok, here are the dimensions for that radiator. Overall Size: 32.00" x 19.00" x 3.00"
Core Size: 26.25" x 16.00" x 1.75". Does the 1.75" thick core sound right?
Old 04-02-2014, 07:57 AM   #6
brian1971
brian1971's Avatar
Brian that is the right size you are good with that one.
