04-02-2014, 12:27 AM | #1 |
Time for a new fuel tank?
I've got a fuel tank that has been sitting with gas in it for some time and has a lot of gunk built up to the line where gas was sitting. It doesn't "appear" to be leaking but after cleaning who knows.
Should I even attempt to clean it or just plan on getting a new tank? Here's a picture of the inside of the tank. Thanks, Travis. |
04-02-2014, 10:03 AM | #2 |
Re: Time for a new fuel tank?
You could try ,hard to clean really good because of the baffle. Try a radiator shop to do it then seal it with a tank kit.
04-03-2014, 12:07 AM | #3 |
You can get a new tank with mounting hardware and sending unit for around $200.
71 K5, AC/Tilt, 4" lift 33" tires 5.3L/4L60E/NP 205 (Under Construction) 05 Dodge 2500 4x4 5.9 Cummins (Daily driver) "Common sense is not so common" My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=555879 |
04-03-2014, 01:02 AM | #4 |
The poly tanks are available also for about $200 with a new pickup/sending unit.
04-03-2014, 09:14 PM | #5 |
Yep, I saw that several places sell the kit for around $200 not including shipping. I asked a radiator shop about it and he recommended going with a new one.
Next question... Poly or steel? I've heard several opinions about which is better. |
04-03-2014, 09:31 PM | #6 |
Save the goose neck off your old tank, might come in handy. New 1's don't come with it.
04-03-2014, 09:32 PM | #7 |
Thanks for the reminder. I've seen that most of the new tanks come with a shorter generic neck.
