Old 04-02-2014, 02:39 AM   #1
62 Longbed
62 Longbed's Avatar
1977 3/4 ton swap to 1/2 ton suspension questions..
I have a 1977 Chevy c20 pickup . Question is do I need to swap the whole front suspension and k-member to change over to 1/2 ton or can I just swap upper & lower control arms with spindles ??? Rear I'm gonna swap axle and leaf springs as a set .. Want the 5x5 bolt pattern .
62 Longbed is offline   Reply With Quote
Old 04-02-2014, 06:31 AM   #2
andrewmp6
Re: 1977 3/4 ton swap to 1/2 ton suspension questions..
I think its spindles upper a arm and tie rod ends but i could be wrong.
andrewmp6 is offline   Reply With Quote
Old 04-02-2014, 08:02 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Everything from the a-arms out will work.
And use all of the 1/2-ton steering linkage.
Keith
Convert to disc brakes.
Old 04-02-2014, 11:32 AM   #4
62 Longbed
62 Longbed's Avatar
Thank You !! Wasn't sure wanted to ask ..
Old 11-06-2014, 01:42 PM   #5
55dude
55dude's Avatar
i'm also wanted to do this swap so i need 1/2 ton spindles and....?
55dude is offline   Reply With Quote
