Old 04-02-2014, 11:30 AM   #1
Hugh Mongus
Water Pump
I am looking for a new water pump for my new crate engine, and no one seems to carry the same pump I currently have. It is listed as obsolete. The one I bought doesn't have the ports for the heater hose. Is there an alternate location I can run the lower heater hose if I can't find a pump with the proper ports?
Currently my top hose goes into the manifold and the lower goes into the side of the pump. The top port on the pump is plugged.
Thanks in advance.
-Jason
USN Retired
Hugh Mongus is offline   Reply With Quote
Old 04-02-2014, 12:24 PM   #2
truckdude239
truckdude239's Avatar
Re: Water Pump
Can you post a picture of the one u have
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-02-2014, 12:29 PM   #3
Lee H
Lee H's Avatar
Re: Water Pump
Thanks in advance.
Plugged as in a plug? If yes then take it out. If not does your radiator have a nipple for the hose?
What application are you searching for?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 04-02-2014, 12:32 PM   #4
jhwkns
Registered Cruiser
jhwkns's Avatar
Re: Water Pump
Is it a long or short pump? You shouldn't have trouble finding either.
This one has ports.http://www.autozone.com/autozone/par...3505_381122_0_
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 04-02-2014, 01:31 PM   #5
Hugh Mongus
Re: Water Pump
That one looks like the one I currently have. I will check the local Autozone for that one. They didn't offer that pump when I went in there yeserday
-Jason
USN Retired
Old 04-02-2014, 01:32 PM   #6
jhwkns
Registered Cruiser
jhwkns's Avatar
Re: Water Pump
Look at the other pictures. It shows ports. G/L
Old 04-02-2014, 03:09 PM   #7
geezer#99
geezer#99's Avatar
Re: Water Pump
FWIW the top hose on the heater should go to the pump or back to the rad. THe bottom hose comes from the intake.
Old 04-02-2014, 03:29 PM   #8
john
member #16
john's Avatar
Re: Water Pump
geezer is right. the bottom hose should be 5/8" and the upper 3/4" sometimes the cores get installed upside down when replaced.
john is offline   Reply With Quote
Old 04-02-2014, 03:34 PM   #9
1968C20CST
1968C20CST's Avatar
Re: Water Pump
What is the correct for this particular motor set up, a long or short?
1968C20CST is offline   Reply With Quote
Old 04-02-2014, 03:38 PM   #10
imjeff
imjeff's Avatar
Re: Water Pump
I'm still unclear on what application.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 04-02-2014, 03:42 PM   #11
MARKDTN
Re: Water Pump
Find another store. Try NAPA or CarQuest maybe.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 04-02-2014, 03:59 PM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Water Pump
67-72 trucks all used short pumps.
Old 04-02-2014, 04:09 PM   #13
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Water Pump
Long or short depends on the bracket and pulley set up. Factory was short pump
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Ol Blue K20 is online now   Reply With Quote
Old 04-02-2014, 04:24 PM   #14
jhwkns
Registered Cruiser
jhwkns's Avatar
Re: Water Pump
So many engines have been swapped over the years. There's really no telling. Bring your core with you for comparison.
Old 04-02-2014, 04:30 PM   #15
Tx Firefighter
Re: Water Pump
The reason I answered him like that was that he asked what was correct.
Old 04-02-2014, 04:36 PM   #16
Hugh Mongus
Re: Water Pump
I'll post a picture of what I have when I get home tonight.
-Jason
USN Retired
Old 04-02-2014, 04:39 PM   #17
scotts72heavyhalf
scotts72heavyhalf's Avatar
Re: Water Pump
I have a spare thats new if you need one, I`ll ship it to ya for like $30 bucks I decided to run a polished one instead.
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 04-02-2014, 05:26 PM   #18
jhwkns
Registered Cruiser
jhwkns's Avatar
Re: Water Pump
Sorry Man, You're absolutely correct. I guess I didn't need to quote you there, but I'm surprised when I see a short pump in anything these days. I brought it up because he seems like a noob, and I didn't want him to get the wrong part.
