Jag XJ6 front axle
Question:
Would this be a more or less straight fit onto my '60 C10? Tempted to go low and diskbrakes on the truck! All the help I can get would be appriciated! http://www.marktplaats.nl/a/auto-ond...reviousPage=lr |
![]() Join Date: Jan 2011
Re: Jag XJ6 front axle
I would say it could be made to fit but by no stretch is it going to more or less a straight fit.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Wouldn't be any easier than using all the bolt on stuff available and factory parts.
EDIT: Of coarse, have to take into consideration your location and availability of parts- I would venture to guess salvage yards there are not stockpiled full of '73-87 Chevy trucks. |
![]() Join Date: May 2010
I don't the know the for sure answer on this. But I used to have a 1952 Ford F-1 pickup. The Jag front end is very popular on these models. But I think that generation on Fords are much more narrow then 60-66 Chevy's. My only advice would be make sure you measure the Jag front end before you make up your mind.
Thnx Guys for the input, @Tincan1966, your absolutley right about gathering parts, indeed no salvage yard stockpiled full of '73-87 Chevy trucks. So when the Jag front end came up for sale I thought this could be a good shot at having a low front end with bags and disk brakes. Gonna send this guy a mail and ask for measurements.
Thnx! |
If I'm not mistaken the Jag measures 59 1/2 inches hub to hub.
#7 | |
Who Me?
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Ol' Blue Viking
I'm putting a XJS IFS/IRS in my 1941 Chevrolet Coupe.
There is a lot of info out there on these swaps. Stateside everyone is pushed toward Mustang II, but Jags are cheap and easier. Real common in OZ. Here is a Jag swap page on the HAMB http://www.jalopyjournal.com/forum/g...hp?groupid=855 here a couple links http://www.ozrodders.com/forum/viewtopic.php?p=341485 http://www.jalopyjournal.com/forum/s...ad.php?t=24785
Driving Paw-paws truck into the Sunset! |
The XJ6/XJS front suspension is also more rugged, designed for a car that closes in on 2 tons. The MII is an evolution from the Falcon, a much lighter platform. The OP has better pickings for them in his locale, too.
I have a mid 80s unit I'm putting in the front of a 1954 Jaguar Mk7 Saloon (sedan), mild custom I'm building. The `54 Jag came with torsion bar orig. The rear is done already with `95 T-Bird IRS. The plan is for bags on all 4 corners. |
I did this write up a little while back, but it was for my F100.
http://www.jalopyjournal.com/forum/s...d.php?t=571296 |
