custom chassis with alot of nice parts
For sale:
1969 C-10 SWB Chassis OEM 12 bolt 6-lug rear end OEM 4x4 truck rally wheels with OEM caps and hardware x4 PorterBuilt Extreme front Dropmember with SBC motor mounts PorterBuilt Rear Extreme Dropmember with bolt on notch(modified for up to 32" tire) and adjustable trailing arms with 2-inboard bridges PorterBuilt front shock relocators(2 types one that is an eyelit style and the other that is a rod style the rod style will have 2 KYB shocks) PorterBuilt transmission crossmember PorterBuilt rubber power steering conversion hose kit PorterBuilt bolt on body drop PorterBuilt front rack notches cut out but not welded PorterBuilt rear lower bag mounts not welded on rear PorterBuilt air management bracket left and right Accuair- 2 3 gallon air tanks Classic Performance Modular 2" drop spindle x2 Wilwood Superlite drilled and slotted 14" 6-piston front brakes Wilwood Superlite drilled and slotted 13" 4-piston rear brakes with internal e-brake Carrier bearing for 2-piece driveshaft Uni-steer power steering Rack and Pinion Flaming River stainless 2 links with steering rod cut for Extreme Dropmember Firestone F-9000 rear bags x3 Slam Specialties front air bags KYB rear shocks 4 shock mounts Michigan Metal Works custom made flat plate upper control arms, narrowed 3/4" with Jeebus Joint upper ball joints and custom 3-d machined Jeebus Joint covers Michigan Metal Works custom made flat plate lower control arms with heavy duty 73-87 fullsize chevy ball joints. Custom bent front brake lines [B][U]This is over $11,000.00 in parts and accessories. This will save you tons of order time, you don't have to spend any money on extra tools for installation, and you save all the man hours it takes to install all of this for $6500.00!!!!!! buyer is responsible for all shipping and if pay pal is used buyer is responsible for fees. I have quite a few pictures these are just a few. if you need something specific let me know and ill get them to you asap. you can email me at mikestein10@gmail.com Thank You. Last edited by belowme51; 05-22-2014 at 03:25 PM. Reason: updated detailed list of pats and pricing. |
Re: custom chassis with alot of nice parts
for those curious yes some of this is from the last time I put a ad up, had some wonderful experiences with "buyers" lol
VA72C10
![]() Join Date: Mar 2008
Would you sell without rear brakes and front brakes/control arms? Interested in a price if so...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
What part numbers on the brakes?
Forged Narrow Superlite 4R Big Brake Rear Parking Brake Kit Product Number: 140-10093-D
Forged Narrow Superlite 6R Big Brake Front Brake Kit (Hub)Product Number: 140-10776-D |
Do you have front rollers? Ideally, I'd come down with a tow bar and haul it back that way.
They can be arranged easily
I'd rec a std towing trailer for this.
So I will part this out gentleman.
![]() Join Date: Apr 2012
The spindles, I'm looking for 73-87 ccp modular drop spindles for my Porterbuilt extreme.
Chad 1967 Chevy C10 "Project DV8ED" 1994 Nissan 300zx convertible 2004 Chevy 2500HD crew cab 4x4 |
How much for the body drop shipped to 05478
///Relaxed Atmosphere |
#13 |
#14 |
I don't know if you want to keep the rear dropmember together but I really need the inboard bridge. Also pricing on one of the pb tank bracket, accuair tank and compressor.
Thanks, Alec |
#15 |
I am interested in cpp spindles, how much drop and price shipped to 27583
#16 |
![]() Join Date: Mar 2014
In line for a arms upper and lower how much
#17 |
![]() Join Date: Jul 2007
Pm sent
#18 |
Update at top
#19 |
VA72C10
Interested in everything...pm sent...
#20 |
Sale pending on complete listing>
#21 |
EDIT: back up for sale again
#22 |
How much for the a arms and control arms?
#23 |
How much for the tank and compressor mounts? With and without tanks and comp?
#24 |
Interested in front and rear brakes shipped to 77087, if you decide to seperate
72' cheyenne super swb (project) |
#25 |
Still interested in the PB bridge if you're willing, 85212. Completely understandable if you want to keep the rear dropmember together. Thanks
