Old 07-27-2003, 04:17 PM   #1
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Signal/horn ???
Ok guys here's the symptom.When I turn a corner the Horn blows intermittently.
My turn signal switch is worn and needs replacing but I don't know if that will cause the problem I'm having.
Also I can't seem to find any diagrams of the horn/turn signal assembly does anyone have one they can send me?
I want to get this taken care of so I can put the horn button,bellville spring and horn cup back in.I'm driving without the horn right now so I don't embarass myself by people thinking I'm honking at the little old lady in the Burke.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-27-2003, 08:26 PM   #2
PanelDeland
ttt
Old 07-27-2003, 08:40 PM   #3
jef5150
Inline 69
jef5150's Avatar
Unhappy
theres supposed to be a plastic turn signal cam with a plastic pillar,,,inside that pillar is a spring with what sorta looks like a small ball bearing,,,,that supplys the ground for your horn when you press the horn button,,,,,sounds like it is cracked or broken allowing the horn to ground out as you turn the wheel,,,,,,,,,im trying to get my scanner to work so i can send you a diagram.....jeff...........******* anyone have a scanner and an original chevy service manual,,,,could you scan fig#19 under steering, section#9..mines a 71 buttttt,i cant get my scanner to "flippin" work
jef5150 is offline   Reply With Quote
Old 07-27-2003, 11:35 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Is the turn signal lever kinda loose? I have seen quie a few trucks come through the shop (Guman trucks used this column for many years as did heavy C/40 Gm trucks and busses) that have loose levers. The lever grounds out on the horn mechanics and honks the horn.
Old 07-29-2003, 01:07 PM   #5
A.P.
Black 72 Chevy
A.P.'s Avatar
http://www.geocities.com/chevroletc1070/wiringdias.html
http://www.geocities.com/chevroletc1070/instrum2.html
A.P. is offline   Reply With Quote
Old 07-29-2003, 08:36 PM   #6
jef5150
Inline 69
jef5150's Avatar
Thumbs up fuzzy
i got scanner working....SORTA....hope it helps,,,i have exploded view of tilt wheel if you need it,,,jeff
Old 07-29-2003, 09:34 PM   #7
Blackhawkdc
440 american Horses
Blackhawkdc's Avatar
yes, simply put, a worn turn signal switch and contact plate, number 31 I believe on the diagram, will cause the horn to honk intermittently
Seth Petro
1969 Chev Short Step
425hp 350, TH400, big tires, fast truck
1979 Pontiac Trans Am
1991 Saturn SL1 - gas mileage! (and free)
1977 Buick LeSabre - for sale
May America bless God, and may God bless America
Blackhawkdc is offline   Reply With Quote
Old 08-02-2003, 06:39 PM   #8
PanelDeland
Thanks guys.I figured I needed to replace the horn and turn signal stuff to get it right.I had a pic from Haynes and thought that was the problem.I just like to have some backup on my diagnosis before I spend the hard earned $$$ for parts.
