04-03-2014, 05:19 AM | #1 |
What is this box doing?
I bought a complete drive line out of a 2004 2500HD for my 1986 Stepside.
The electrical system from the donor truck came in a big box together with misc parts. Im going to use a new harness for my truck so most of the stuff I will probably not use. When I went trough the parts I found this little black box togeter with the ECM. Anyone that can tell me what itīs for, and do I need it?
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
04-03-2014, 06:13 AM | #2 |
Re: What is this box doing?
TAC module for the drive by wire.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-03-2014, 07:55 AM | #3 |
That is the tac module for the dbw pedal and thottle body so yes u need it
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-03-2014, 09:26 AM | #4 |
As the other stated, its the Throttle Actuator Control (TAC) module. However, that one is for a 2000-2002, not a 2004, so it may not work for you. Are you sure your engine is an 04?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-03-2014, 10:00 AM | #5 |
the pcm is for 03-07 so it might be
04-03-2014, 12:11 PM | #6 |
Thanks for the replies! I had an idea that it would be needed.
I was not there my self when it got pulled out of the donor truck, but I'm quite sure that it is the unit out of the 2004. But I will check with the seller just to be sure.
04-13-2014, 10:25 AM | #7 |
All of it needs to be out of the same vehicle or headaches abound!! Or at least from the same year. Tach module, pedal, and computer have to all match or this get screwy. Make sure when u take to the supplier that all if it matches and it will all go smoother
04-14-2014, 05:14 PM | #8 |
I had a chat with the guy, he took pictures of everything when he took the donnor truck apart. He sent me the pictures so it's clear that it came from the same truck. The truck was drivable (hit on the side) he even had a short video of it running.
So I think it will be ok.
