No Start on a 2001 chevy 1500
im stumped. I got a 2001 chevy 1500 with the 5.3 liter motor. No start, i put a new battery in the truck, cables look good. Removed and had the starter tested, starter is good. Checked relays/fues. Installed a new safety neutral switch, still nothing. Any ideas?? I have power going to the starter..
![]() Join Date: Sep 2005
Re: No Start on a 2001 chevy 1500
Does tge motor crank (spin) and not s tart or no crank no start
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
the motor will not crank, will not turn over
i connected my remote starter switch and the trucks starts right up. im guess i need a ignition switch? how hard of a job is this to install?
im stomped, new ignation switch, still the motor will not turn over
OK, I'll give this a try. This is assuming you have a automatic trans. You must have 12 volts on wire #639, it comes from your under hood fuse box and goes to your PNP (park neutral position) switch, it is pink. From there it comes out of that switch as a dark green wire #1433 and goes to starter the relay (also in the under hood fuse box) that circuit provides the 12 volts to the relay. For the ground, it comes from the PCM (power control module) it leaves the PCM on pin 39 of the C1 connector (C1 is the blue 80 pin connector). If you have both of those then the relay has all it needs to close the contacts. Now, on the other side of the relay are the working contacts. The input source is 12 volts from your battery through fuse IGN A, it is a 40 Amp fuse also located in the under hood fuse box. The output of that relay is a purple wire #6, it goes directly to the starter solenoid. If you have power on this wire when you are trying to start and the starter does not spin then your problem is the solenoid or no ground on the starter itself. Have a look at these things and reply.
Good luck. Rob
My '47 C.O.E build |
