Be careful out there
Just a reminder to be careful i just god scared to death i was ajusting carb when i dropped the screwdriver hit the fan clocked me in the head and stuck in my hood. I just couldnt believe it i thought i cracked my head open then thoughts of it sticking in my eye im still shaking so be careful out there
I am always worried about stuff like that when the engine is running.
I have a flex fan and the stories about fan blades breaking off and cutting up hoods always flash through my head when I'm under there. Glad you're not hurt! |
thanks i was gonna get a flex fan but dont have to hear stories a friend of mine had it happen lucky he was driving not under the hood
its all about the +6 inches
It'll really scare the pee out of you if you reach in and your finger gets smacked by the fan.
Happened to me 3 times now, and I have been lucky so far, every time I have been hit on the finger nail and not flesh. |
#5 | |
Bloo
ive had that happen once with the fan, i think it got me on the knuckle though.. somehow it didnt cut me, the ford was just warning me not to touch it i guess
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
ive been hit on the finger by a fan and it wasnt bad at all
FOUNDING MEMBER OF THE DRUM BRAKE CLUB 69 c-10. turquoise. 350 motor with 400 trans. long fleet. headers and dual flowmaster exhaust. K & N air cleaner, aluminum wheels and radials, stereo system and a bed liner. Manual drums and manual steering. Kickin it in Seattle, WA p.s. i love my longbed. must be a phallic thing. |
I was doing the same thing, fine tuning the idle mixture when I fumble fingerd the screwdriver and it got in the fan and took out the radiator. That bent screwdriver is hanging on my tool box just for a reminder.
72-C-10-LWB-Big Block-TH400- PosiTrac Leaf Springs- A Dark Green Ford Eaten Machine. And those are not rust holes, there cooling vents.. |
yeah - i've gotten my finger in the fan before, and it smarts, but it never broke the skin.
wow - that whole screwdriver thing has me rethinking things! whew - you are lucky! thanks for the tip! jewels.
68 C10 Red Step 350 my first child & main focus 58 3200 Apache LWB Step the upcoming project |
Yeah me too: While rowing thru the gears on my muncie with a hurst lock out, I heard a piece of tin hit the ground. I pulled over and popped the hood and found one of the fan blades had sheared off and took out the top of my shroud and there it was sitting on the intake manifold, I have not driven it since and the next time I do it will be to go to an auto parts store for a new fan and glue to fix the shroud!!!!thank god it hit the shroud and did not go through the hood.........
StepSideRideRequired |
Low & Slow
I hear you Longhormail! I wasn't thinking and dipped my hand down while i was reaching back from tuning my carb. I didn't want to look down, I thought I cut the tip of my finger off it hurt so bad. It turned out I had a little gash above my fingernail. I'm usually lucky with stuff like that.
70' C-10 LWB Fleetside 4.5/6 drop ![]() |
There are accidents like dropping a tool in the wrong place while the engine is running. And then there is downright stupidity. I remember a deckhand working on a fishing boat wanted to check the tension on the alternator belt...while the engine was running. It ran his fingers right thru the pulley and messed him up.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
My other Love
well i was trying to turn over my motor with a socket (engine off) when the socket slipped off and my thumb got sliced right open by the flex fan, those things friggen sharp!! man did it bleed, should of gotten stiched but being the Macgiver that I am I just stuck super glue in there and kept working.
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
#13 | |
That's what Super Glue was invented for. . . .
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
#14 |
Call me a puss puss, but I refuse to come in from the front of the truck when it's running. Currently there's no shroud as I'm still balls-deep in the paint / assembly portion of the project, but if it's running, you can bet your sweet a$$ I'm coming in from the side to do something.
#15 |
Don't get a Flex Fan!!!!!!!!!!!!!!!
Keep Org. or get electric! Save your arms teeth and Hood! ![]() |
#16 |
I have the dual electric fan, but that wasn't what got me.....It was the belt! I was tuning the carb, and was more worried about the fan when my arm grazed the belt. Kinda like road rash, but only a half inch wide!
U.S.A.F. 68' C-10 Stepside 305 w/ 4 speed |
#17 | |
i'm pretty short (5'5"), so i cant reach much from the front --- so i always come at things from the side - esp when she is running -- but even then, i still manage to act like a clutz and get my finger in the fan! interesting.... ![]()
#18 |
Life is Good !
did the same thing like a year ago. I was tightening up the radiator hose and lost the screw driver, and my fanschourd, and the screw driver stuck in the radiator. Bad day
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
#19 |
Thanks for the reminder.
I have a constant reminder because when I was 15 I found out that a metal fan connected to a running big block is just a bit stronger than my fingers. After a trip to the emergency room and a few too many stitches, these phantom pains are still around, something about cutting off nerve endings, whatever that means ![]()
Jeremy '71 C-10 '72 GMC K2500 '72 Nova (Dad's) '70 Chevelle SS '55 Sedan Delivery Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall |
#20 |
Being 6'1" it's easy to reach the carb and what not from the front. The problem with that is when you're leaning in that far, the parts of you exposed to the fan are your neck and chest. I'm good with having no screwdrivers sticking out of my neck.:p
#21 |
I hear you guys. I'm 6' 4" so I can lean in no problem but when you lean in with a sweat shirt and the strings start hitting the fan that scares ya. I also know a guy that was working on a bulldozer from underneath (running) and shoved his hand in the fan. Cut it off. Ouch!
#22 |
Bloo
jewels, i know what its like having to come in from the side to work... (see pic, im only 5'7") but the time i got my finger in the fan i was coming from the front, only time its happened so i'd have to say yup to your question
#23 | |
Binder Rep
The reason you can get lucky sometimes is the direction of rotation.. since you come in from behind the fan it pushes your finger out of the way with the slant... if you got in front of it it'd pull your finger in/ chop it off. You have to stick your finger in a lot farther from behind to get the sharp edge instead of slant, and it moves so fast it's hard to get it in that far before it gets pushed out... fortunately.... When I set the timing on the IH, I'm always paranoid about the belts and all being so close to my hands... that's one time when I'm glad the dizzy is in the back on the chevy... well I guess it's the only time, but anyways... |
#24 | |
![]() Blue_71 - i really like that picture of your truck! looks sweet! did you ever notice in that picture that your baseball cap matches the color of the truck, and your blue jeans match the color of the bowtie emblem on the truck? you and the truck match! you are made for each other! ![]() ciao! jewels. ![]()
#25 | |
Binder Rep
