How to deal with rusty bolt holes?
I took my door panels off my 1971 chevy C10 custom yesterday and changed the door locks. In the process, I stripped one of the stainless fasteners. I managed to get it out, carefully, but then I had to replace it. I went to Ace Hardware and found one that was SIMILAR, but not quite perfect. In addition, I'm left with very rusty machine screw holes.
How should I clean up these holes? And what should I put in there when I'm done? These looks pretty close to stock: http://www.classicpartsusa.com/produ...71_Truck_Parts |
![]() Join Date: Mar 2003
Re: How to deal with rusty bolt holes?
lightly spray the hole with some PB blaster, run the 1/4-20 tap through the hole with some additional blaster----done...then install the screw with a dab of anti-seize. I have more problems with stainless steel screw fasteners than anything else
![]() Join Date: Jul 2010
X2^^^. I use an Anti-Seize brand called "Cop-Graf", it has a blend of copper and graphite designed to plate metal parts with a protective barrier guarding against rust, corrosion, seizing and galling. Also really good on exhaust bolts. It's rated for tempatures up to 1800 degrees Fahrenheit.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
Word. Bought a hss 1/4-20 rh bottoming tap from fastenal, then pb-16, anti sieze, dark cutting oil and a tap handle from amazon. Should be fun to clean those up when the parts come in.
I sand blasted all my inner door parts when I had them out
