04-03-2014, 12:01 PM | #1 |
Rear diff rebuild
Anyone out there know about the 283 stock rearend gear ratios? I have built up a 1958 corvette 283 semi-performance. The truck has a existing 3:54 posi dana 44 in it. The diff is growling and I picked up a 12 bolt diff from a 79 blazer with 3:08 gearing, rebuilt it and wondering if that is going to be too high gearing for the application.
"gotta love something that works without a computer" |
04-05-2014, 05:36 AM | #2 |
Six in a row makes it go...
Re: Rear diff rebuild
What transmission?
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
04-05-2014, 11:48 PM | #3 |
60-66 Nut
The 283's don't produce good low end torque, so the 3.08's may be too high. Of course this depends on the tire size as well as the trans as Shaky said.
04-08-2014, 12:00 PM | #4 |
04-08-2014, 12:02 PM | #5 |
With the 3:54's I'm shifting into 4th gear around 35 miles an hour. With the standard trans SM-420 find myself chasing gears all the time.
04-08-2014, 04:40 PM | #6 |
I think you're gonna need all the gear you can find to make up those big rpm drops on the SM420.
04-09-2014, 12:12 AM | #7 |
Are you saying the 3:08 gears are going to be to high for the existing set-up?
04-09-2014, 05:08 AM | #8 | |
It all depends on whether this matters to you or not. Ultimately, I plan on either a Ranger or Gearvendors overdrive to make my SM420 into an 8-speed.
04-09-2014, 11:29 AM | #9 |
The main thing is I'm chasing gears right now with the 3:54's but I believe this was a stock set up with the original trans and full set-up from factory with the stock 283. My concern is will I be lugging with in town driving with the 3:08's. The 3:54 is a dana 44 posi, the 3:08 is a gm 12 bolt no posi. I have rebuilt the 12 bolt diff bearing shims etc. Before bolting this in I just want to be sure.
